    Looks like a ground loop isolator. I use one on my factory AUX connector and bluetooth adapter, as sometimes the stock radio switches from the aux back to radio randomly without it
    Thank you! That makes total sense.
      Has anyone successfully installed a Bluebus module without having the pre-wiring for a CD changer? I have torn my entire trunk apart and now realizing my Canadian M3 is not pre-wired.
        Hey everyone !
        I'd like to buy a Bluebus adapter for my car with the telephone cable but I am not sure of what phone adapter to buy ?
        I looked in the trunk but did not find any connector as described on the bluebus website.
        Here are a couple of pictures of the electronics in the trunk.
        Is there anyone knowledgeable that could tell me what phone cable adapter I need ?
          Originally posted by Flow View Post
          Hey everyone !
          im sure tedbm3 will chime in but your car is the exact same as mine (euro spec) You plug the Bluebus into the CD changer connectors. You cannot use the CD Changer after that.
            Thank you for your answer ! I'll wait for more details
            When you use the CD changer connector, does a phone call still take priority when listening to the radio ? Is there any drawback ?
            I'm kind of sad to loose the CD changer, it's kind of vintage and fun. I like my tape deck behind the nav screen too lol.
              Yes I am sure you and I have the exact same optioned car, basically fully loaded. It'll work perfectly fine.
              Happy to lose the cd changer lol
                As above the CD changer is disconnected and can be removed. There's a 6 pin and a 3 pin connector for. That's for just music playback and control - no phone functionality.
                The top module is the ULF or TCU (Bluetooth). You'll need a cable to adapt from that 54 pin connector to the BlueBus.
                A fully integrated Bluetooth module for your vintage BMW
                  https://www.bluebus.dev/telephone-adapters
                  Thanks for your help !
                  I still somehow cannot figure out exactly what I need to order.
                  Do I simply need a Bluebus and this on top of it :
                  54-Pin Adapter Quantity ($33)
                  Correct ?
                  Thanks again. Florian.
                    I just installed mine today and it is normal to show CD 7-01 periodically when you push the numbers or change a track?
                        Yeah I went back to first page and saw someone asked the same question years ago. Haha. Appreciate the response though.
                          Correct ?
                          I did not buy the adapter, hhmmm might want to message t3ddftw directly.
                            I did not buy the adapter, hhmmm might want to message tedbm3 directly.
                            Thanks man. I've sent an email to [email protected]
                            I'll report back if I get an answer
                              Hi everyone,
                              I’m running BlueBus in an E46 330Ci Cabrio (EU car, no factory telephone pre-wire).
                              I’d like to use the full telephone path (hard MUTE/TEL-ON + Tel Audio ±) in addition to the normal CDC T-harness, so that calls interrupt regardless of the current source—i.e., like the OEM ULF behavior.
                              Is there a custom plug-and-play adapter loom that:
                              • plugs into the BlueBus 6-pin telephone header, and
                              • breaks out the four radio lines to the back of the head unit, plus
                              • provides two wires for the OEM microphone from the steering-column grille?
                              Kind regards
                                I'm on the latest firmware and I'm noticing that my clock keeps changing to AM, even if i go in and change it to PM, if i stop and start the car, the nav shows AM time? Anyone else seeing this?
