Originally posted by bavarian3
View Post
Affordable BBK Option - Brintech Customs
Do you have some info about these Alfa calipers you can share? What are the piston sizes, pad shapes, and is there a part number for the caliper?Originally posted by bavarian3 View Post
They basically pull from a Chinese source. Signature werks does nothing fabrication wise on their end. So their source machines down(bad) some ZL1 calipers and adds some brackets, then uses some huge 380mm Chinese(possibly not bad but probably) rotors to complete the kit. They do look nice though.
I'm in the process of collecting parts for an Alfa Romeo retrofit which doesn't require any machining of the calipers. Will review once done but basically you source Quadrifoglio calipers, freakyparts brackets, and e92 m3 360mm rotors.
I don't have the piston spec on hand but basically any stevlio or giulia 2.9 quadrilfoglio caliper not meant for carbon ceramics will work. Like these: https://www.ebay.com/itm/334862231593. Pad is the same that they normally use. Plenty of pad options cheap to very expensive.Originally posted by Nate047 View Post
Just have random pieces from kits left like RR brackets, textar pads, some retainer clips, etc.Originally posted by m3_tristan View Post
Are you still selling?
no full kit, no calipers at this time.
price of calipers went up since this post and made the full rebuild out of reach for many people unfortunately. I stopped as for the price it takes, other setups become within reach2006 ILB | M-Texture
What did you need to do?Originally posted by r4dr View PostI’ve had to help a customer clean up their mess of a Signature kit. The only part worth anything is the caliper itself, assuming it is even genuine Brembo that is machined properly.'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
Originally posted by r4dr View PostThe only part worth anything is the caliper itself, assuming it is even genuine Brembo that is machined properly.
I don't understand the bold part.... if you helped someone with their kit, you would know if it was a real Brembo caliper, no?
2004 Dinan S3-R M3
2023 X3M Competition
The customer had pulsation under braking and really hated the pads that came with the kit. The pads were easy -- these calipers use a very common pad shape, so we set them up with some quality street pads to start with.Originally posted by jbfrancis3 View Post
The rotors had a lot of variations in disc thickness which is certainly what caused the pulsations. This is typically due to poor machining tolerances, both in the hat and rings, and rears its head after use. Think "warped rotor" but not due to heat.
Luckily, they modeled the rings after Brembo replacement rings which we had our replacements for. We made the assembled rotors flat for the customer, but I think putting flat rings on their hats would result in a questionably flat assembly due to the hats.
I did not see the car in person. The customer shipped the rotor assemblies to us after calling us looking for advice with his issues. I took the project on because I liked the guy and wanted to help a fellow E9X enthusiast out.Originally posted by 9kracing View Post
There is a rash of Brembo fakes out there that are very, very convincing. To the point where they even have the same Brembo part numbers in their casting molds. There have always been knockoffs floating around but they've gotten extremely hard to differentiate from real Brembo calipers.'03.5 M3 SMG Coupe - Jet Black / Black
- Likes 3
Appreciate that, and I understand why the customer was not happy. Nice of you to help out. I've been street driving their E46 kit for a year (type 3 rotors, with their carbon ceramic pads) and have not experienced those issues. I half-expected for it to be trouble like it was for your customer.Originally posted by r4dr View Post
Luckily, they modeled the rings after Brembo replacement rings which we had our replacements for. We made the assembled rotors flat for the customer, but I think putting flat rings on their hats would result in a questionably flat assembly due to the hats.'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
Do you know if those calipers are used on other cars as well, or are they exclusive to those Alfa models? They look similar to some others out thereOriginally posted by bavarian3 View Post
The pistons are 30/34/38mm.Originally posted by Nate047 View Post
Uses the D1116/1365 pad shape (1116 is just 1365 with the pad wear sensor cutout). Easy cross-reference is '18+ STI front pad shape.'03.5 M3 SMG Coupe - Jet Black / Black
- Likes 2
