Unboxing a Karbonius Carbon Fibre Vented Engine Cover
    here You go boys i had one few months back witch i did sell
      As cool as that is I still prefer the stock/karbonius one. With the airbox you'd have to decide which piece is going to have the m power vinyl on it.
      That cover also needs to be modified to work and is generic looking as well since it's purposeful.
        Looks like Karbonius has another option for carbon engine covers and this one is in 1x1 vs 2x2 weave. Yours for only $850 sans emblem =)
        This is an interpretation of the Carbon Engine Cover that BMW had on the Concept M3 CSL which had a vertically laid carbon weave compared to the typical diagonally-laid weave. Made in carbon fiber prepreg in aluminum mold and cured in an autoclave, lends the best finished you can find on the market and a major thermal and structural stability. With an awesome appearance, the high gloss finish accentuates the carbon fiber weaves, and provides UV protection. The piece uses Monoblock Construction, which means that there are no pieces glued that can be released due to vibrations or the heat of the engine and is trimmed in a 5 axis CNC machine, so fitment will be perfect and easy to install. All our pieces are numbered, so its origin and authenticity are granted. Does not include "M" Emblem. Kit Includes: Karbonius S54 CSL Concept Engine Cover Stainless Steel "CSL" or "///M" Plate Certificate of Authenticity Product Features: 100% Carbon Fiber Prepreg Attractive minimalist aesthetics Reduced weight Easy installation Cured in mold and in autoclave CNC trimmed Exclusive and numbered piece 2 years warranty OPTIONAL: OE "///M" Emblem Application Guide: BMW M3 / M3 CSL E46 BMW Z4M BMW Z3M with S54B32 ONLY
          Their csl concept one has been out for awhile.
          Installing that on an m3 is like a 330ci putting on an m badge, just not as big of a violation.
            Don't remember where I found this photo, but I absolutely love the look. Would love to see a cool retro/throwback design like that for the S54.
              Originally posted by poss View Post
              This cost me my left testicle (luckily I have a spare). Although Karbonius listed this as 'in stock' it took several weeks for them to manufacture (they offered me a different carbon fibre to the one I ordered - which was refused).
              Luckily Fedex delivery made up in some part for the delay - was very snappy from Spain to Oz.
              Quality appears impeccable. Nice recess for M badge (pity it's not included for the price)
              Main fear is it's gonna show up everything else under the bonnet once installed
              Did you ever fix this? any update? I am about to buy one.
                your post got me wanting to check mine. i've had the engine cover in possession for quite some time, but wanted to install at the same time as the intake. fwiw, mine came just like OP's along with some washers
                /// 2004 SG/IR - Build Thread
                  Thanks for sharing. it seems is just the nature of the beast, even the original motorsport one is like that.
                    of course, no problem at all.
                    yeah, it may just be how these cf covers are designed, although the photo shared by ocean from the Karb website makes it seem like there are/were some supplied with those metal dowels. I'm sure it presents its own set of issues. I guess the CF is strong enough and as long as I don't overtighten and spread out the force with a washer, it should be okay?
                    which one were you thinking about getting and in what finish? just curious
                      Ordering tonight. Will get the CSL concept in 2x2 gloss as my intake is like that. I am debating between CSL or ///M script. I know my car is faaar from a CSL as mine is a Z4M, but I already have too many M’s in the engine bay.
                        Would love to get the CSL concept one with ///M script in 2x2 Gloss CF to match my OE CSL intake. Wish they made one that said CS
                          Placed the order for the CSL concept version, and chose 'CSL' script. we will see. I ordered directly from Karb as opposed to IND, which if I am lucky and do not need to pay taxes will be cheaper including the ///M logo to finish it up.
                            Adding my experience. My CSL concept cover came in and the quality is excellent. Still need to fit it and also, is this a 1x1 or 2x2. I am sure I spec’d 2x2 but not sure.
                            Click image for larger version  Name:	IMG_1532.jpg Views:	15 Size:	149.6 KB ID:	291546
                            Click image for larger version  Name:	IMG_1528.jpg Views:	15 Size:	137.7 KB ID:	291547
                            Click image for larger version  Name:	IMG_1535.jpg Views:	16 Size:	166.6 KB ID:	291548
                            Click image for larger version  Name:	IMG_1534.jpg Views:	15 Size:	161.2 KB ID:	291549
                            Click image for larger version  Name:	IMG_1529.jpg Views:	15 Size:	146.6 KB ID:	291550
                            Click image for larger version  Name:	IMG_1530.jpg Views:	15 Size:	144.5 KB ID:	291551
                            Click image for larger version  Name:	IMG_1531.jpg Views:	15 Size:	183.5 KB ID:	291552
                              2x2. What might be throwing you off is the weave is going straight along the piece rather than at a 45 degree angle.
                                I have installed the cover, I did not see any comment about transferring over the grommets for the PCV or the oil cap, but I did and they fit just fine.
                                however, the cover does miss material to sit flush / net on the stud bases, there is a gap of 2-3mm and the washers provided are not enough to fill the space. So I temporarily used some weld nuts I had laying around, I will measure and try to get the right size spacers. Also the holes on the cover are a bit tool large, so the washers are needed between the cover and the nuts.
                                Click image for larger version  Name:	IMG_1537.jpg Views:	5 Size:	184.5 KB ID:	291681
                                Click image for larger version  Name:	IMG_1538.jpg Views:	5 Size:	156.1 KB ID:	291682
