Epoxy/Rivet Vince Bar - Epoxy options besides Araldite 2014
    I cannot seem to find anyone that has the recommended Araldite 2014 epoxy in stock. Can anyone recommend some suitable alternatives?
    Thanks.
    Jesse
    Old, not obsolete.
    Thanks.
    Jesse
    I ended up using a 3M product designed for the same purpose. If nobody has replied by this weekend, I can get the PN for you then.
      Maybe 08115 Panel Bonding Adhesive?
      Old, not obsolete.
        This is what I used.
          Worked out okay?
          What part of Atlanta are you in. I am in Marietta.
          Jesse
          Old, not obsolete.
            Worked out okay?
            Jesse
            Worked out great for me, used it on the underside plates as well. There are a couple of pictures in my journal of my Vince Bar install.
            https://nam3forum.com/forums/forum/m...grey-speed-run
            I'm usually in Alpharetta but currently stay in Marietta for school.
            Do you happen to be the guy driving that super clean Imola E46 M3 around here? I see that car quite often in Marietta.
              Nope. Silver Grey in East Cobb.
              Old, not obsolete.
                Nice, do you ever come to any of the CCA meets? Haven't seen many other silver greys in ATL.
                  BMW CCA? No. Where and when?
                  What lead you to the 3M product?
                  Jesse
                  Old, not obsolete.
                    Jesse
                    3rd Sunday of every month at the North Point Barnes and Nobles. Starts at around 9 AM I believe.
                    I used the 3M stuff since it's just a name I recognize, and have had a bunch of quality products from them..... I have family that works for them as well.
                      I've never been disappointed with a 3M product.
                        Me either. I just don't have the expertise to select the correct 3M product.
                        Old, not obsolete.
                          I have had good luck with 3M as well, but there are a lot of options from them. I appreciate your help.
                          The BN is close to where I work. I will need to get out there to a meet once I get her put back together.
                          Jesse
                          Old, not obsolete.
                            That's what I used in 2012 to put in my lower plates. Zero issues since.
                            Mike
                            02 M3 Titanium Silver / Black
                            11 Tundra SuperWhite / Black
                              How much epoxy have you guys needed to install a Vincebar and Vinceskinz?
                              Araldite 2014 is currently available in 50ml cartridges. It would end up being a little more expensive than 3M 08115, but it is what Vince recommends.
                              Vince also recommended the 200ml cartridge. Besides cost, is there any reason to not use 50ml cartridges?
                              2003 Imola Red M3 w/ SMG
