What oil?
    Having reviewed the original specs of Castrol TWS, the closest I have found to this is Fuchs Titan Race Pro S 10w60. Castrol's own current Edge spec is not quite as good as the old TWS. You can actually verify all this from comparing the data sheets provided earlier in this thread and judge for yourself.
    Standard Titan Race Pro S Castrol Edge Castrol TWS Shell Helix Ultra Racing BMW Twin Power
    Kinematic viscosity 100°C mm²/s IP71 24.1 22.7 24.2 22.8 23.1
    Kinematic viscosity 40°C mm²/s IP71 163.9 160 161 151
    Viscosity index (A) IP226 179 173 179 174
    Specific gravity (density) 15°C IP160 0.869 0.853 0.864 0.846 0.845
    Flash point - Celsius IP34 200 203 200 215 250
    Pour point - Celsius IP15 -39 -39 -51 -39 -42
    Sulfate ash content (% wt) N/A 1.29 1.1 N/A
    Cold crank viscosity -25°C ASTM D5293 6100 4879
    API SL, SJ & SH SN, CF SN, CF SN
      Out of curiosity, how do you come to the conclusion that it's not as good? Thicker at 100*C? Seems like comparing numbers out of context doesn't tell the whole story.
        The one spec on there that might influence my decision is sulfated ash. Lower is better, assuming all the oils seemed roughly equivalent for my application otherwise. Too bad it's not published for all oils.
        2008 M3 Sedan 6MT
        2012 Mazda5 6MT
        A few Volvo parts
          Perhaps I should rephrase it as to saying it's not as good a match to the original TWS specification as the Fuchs is. Also, the Fuchs being ester based is allegedly far more shear stable than other non-ester based oils.
            Ravenol looks the closest to the old formulation of TWS to me. Very similar VI, lower pour point, higher flash point compared to Fuchs.
            As we know cold start performance is one of the most important attributes in an oil for our cars if street driven. Ravenol and the original TWS have the same pour point as a 0w40.
              Has never failed me...
                Love my liquimoly 10w60 change every 7500 miles
                  Couple of understandable but important misconceptions here.
                  Specs like what Mike RT4 posted are related to important aspects of oil formulations, but they can't tell us which oil's formulation is "closer to" or "better than" any other in any meaningful way. A higher VI could be due to better base stocks or higher levels of polymeric additives. Lower pour point could mean more PAO or a lot of pour point depessant. Sulfated ash could come from any combination of anti-wear, anti-friction, or detergent/dispersant additives. And there's no guarantee that the numbers even mean anything in the first place because there could be batch-to-batch variations that are larger than the differences among oils. To know which formulations are more or less "like" each other, we'd have to know base stocks and additive packages in detail as well as the performance specs of the finished formulation. That stuff can't really be inferred from a spreadsheet, and oil companies aren't likely to divulge it. Actually, the real real test is how it works in actual engines. But that's even more out of reach.
                  Cold start performance is indeed vitally important. The best indicators of that are not pour point, but CCS and MRV. Those simulate actual pumping. Pour point just tells you at what temp the oil will no longer move, which isn't necessarily related to viscosity above that temp (honey has a lower pour point than water, but that hardly matters above 0º C). Notice the two oils in the table that have CCS numbers listed: Castrol Edge has a better number than the Fuchs even though they have identical pour points. The highest pour point on the table is -39º C, and I'm pretty sure few people here will ever cold-start an M3 in temps below that, so any extra margin on that spec is... perhaps interesting, but not meaningful in practice.
                  2008 M3 Sedan 6MT
                  2012 Mazda5 6MT
                  A few Volvo parts
                    Thank you for such a detailed response. It’s been awhile since I’ve stepped into an oil thread - glad I did- I learned something.
                      Anyone ever run 5w50? Hear that’s supposed to be good stuff
                      Instagram: @_Frank_Stone_
                        My understanding of the CCS figure was that it was just used to confirm the oil's viscosity rating?:
                        CCS Test Limits in SAE J300:
                        SAE Viscosity Grade : CCS (mPa.s)
                        • 0W : 6200 @ -35ºC
                        • 5W : 6600 @ -30ºC
                        • 10W : 7000 @ -25ºC
                        • 15W : 7000 @ -20ºC
                        • 20W : 9500 @ -15ºC
                        • 25W : 13000 @ -10ºC
                          Oil temps with Motul on hot FL summer days are around 180-190 cruising. The only time it goes above 210 is when I spend 10 seconds above 4500 rpm. TWS was always around 215 under the same conditions. Highway cruising was 205 to 210. It also doesn't burn at all. That's all I got for objectiveness because I'm not getting that deep into it until after I take Chem. Then I'll sort of know something useful.
                            • 0W : 6200 @ -35ºC
                            • 5W : 6600 @ -30ºC
                            CCS and MRV ratings help determine the W part of a multi-grade viscosity rating.
                            The limits you posted are the maximum numbers for all the grades. E.g., anything below 7000 mPa*s @ -25º C qualifies as 10W -- though per SAE specs, an oil must be labeled with the minimum W rating it meets; presumably it couldn't go too much lower before it'd also meet the 5W spec for -30º C. However, there's still room for variation within any viscosity grade.
                            2008 M3 Sedan 6MT
                            2012 Mazda5 6MT
                            A few Volvo parts
                              Which Motul?
                              2008 M3 Sedan 6MT
                              2012 Mazda5 6MT
                              A few Volvo parts
                                Which Motul?
                                10W-60 X-Power
                                No additional additives or anything.
