S54 oil pump chain
    Right, it is to avoid oil leaking out between the head and top of timing cover. So the head gasket has the thin sealant beads to be compressed by the head onto the timing cover to seal. So if the head is attached to the block, and you slide the cover horizontally to the block, through the dowel pin, the timing cover will scrap off and damage the head gasket sealant beads, no other way around this. People doing this way tried to fix the problem by adding sealant to the head gasket and to the top surface of the cover, but during installation, the cover will wipe off the soft sealant and no guarantee there is enough sealant left on the surfaces to seal the oil. It's a risky method compared to install the timing cover first, then the head on it.
    I have NOT said I reinstall front covers "horizontally". I have stated that is do that with the pan off. FAR different. Installing the front cover with the head and pan in place is a method that almost GUARANTEES a leak -- or TWO !!! I thought I would clarify that. How careful and aware am I about the portion of engine? When I have a a 50 or 52 block decked, I have the machine shop install the front cover to match the surfaces. I may be a "shadetree" mechanic, but only because I don't have a business license. Some "indies" actually call me for input from time to time, and even "subbed" 30s or 36s to me. Comebacks suck, so I avoid them. And in 14 years, only two, and they were vacuum leaks. (Solved that some years ago with a smoke tester.)
      We all fully aware that you will install the chain cover with the oil pan off, but you have to install the chain cover by pushing it to the block horizontally due to the dowel pin, as it is the only way with pan or not.
      No one here doubt about your skill, but the situation with the head in there, the gasket sealing surface will be scrapped on stead of pressed on.
        Well, I guess I beat the odds with the ones I've done !!
          I think it is very possible to be OK without removing the head. But there is that chance. Before tackling this job, I think it would be good to know that there is this possibility. Me? I'd just leave the head on and take the chance.
            Originally posted by thegenius46m View Post
            Can anyone confirm if the timing chain on these motors actually stretches a measurable amount? I'm reassembling my motor this weekend and am trying to figure out if I need to order a chain last minute? General I was under the impression that these don't really stretch much... I have all new timing guides (all 3 and the oil pump chain guide) as well as a brand new spring tensioner. Debating if the chain really is worth an extra $100 if it will pay off in the long run? Anyone here who has actually built an S54 here care to share their insight?
            I replaced mine during the rebuild. Only reason was "while I'm in there". I did not measure the new/old chains.
              That's too bad man would have been great data points.
                Welp glad my motor is apart right now. Head is going back on this weekend but timing cover is already off so I am going to have the oil pan pulled and on reinstall the timing cover will go in first then the oil pan so no gaskets are compromised. I was already planning to do the oil pump preventatively anyways in the next 10k miles so decided to bite the bullet and ordered a new OE BMW oil pump and IWIS oil and timing chains. All tensioners were just done. Just going to have my shop do that at this point because I don't want to deal with it on jack stands, nor do I want to learn the hard way first time doing this shit lol. Car has been down almost a year while I battled health issues. I just want it done so I can start driving it again and move on.
                2003 E46 M3 TiAg/Cinnamon 6MT
                2005 E46 330i ZHP Imola/Sand
                Instagram:@thegenius46m
                  Feel better bro.
                    Original timing chain for anyone wondering. That would indeed be IWIS
                      Did you happen to compare the lengths of the two?
                        I can lol
                          The tensioner for the oil pump chain cannot be replaced from below with pump removed, is that correct?
                            Not sure but I don't think so. Maybe someone else can confirm. Interested to get some confirmation.
                            Did I help at all?...lol
                            The tensioner sits on a pin. Not sure if there is enough room between the timing cover to slide it off. Might be able to remove the pin with the tensioner on it. I do believe those pins just screw into the block.
                              I had the pan off and I didnt see a way to replace the tensioner without taking the timing cover off.
                                Anyone else have success R&R'ing the timing cover without head removal? Mine is already leaking but I suppose that could be made worse.
                                I remember doing an audi timing chain job and the factory instructions allowed you to install the timing cover without removing the heads. The heads/head gaskets protruded maybe an inch out, so not as much as the S54. I remember the manual had you chamfer the alignment dowels for the cover to allow for more of an angled installation rather than staight on. With some drei bond on the HG all was well and that was a massive cover.
                                Click image for larger version  Name:	20240409_110039.jpg Views:	0 Size:	221.5 KB ID:	306749 Click image for larger version  Name:	20240409_110055.jpg Views:	0 Size:	196.1 KB ID:	306750
