Are header wraps good ?
    Need some input are header wraps worth it ? What are the pros and cons for a non daily driver car ?
    Brand- Stainless from Active Autowerke
    Pros - none
    Cons - rust, cost, waste of time
    Keep the heatshields in place.
      Even for stainless steel headers from Active Autowerke?
        What problem are you trying to solve?
          This ain't a twin turbo Gallardo.
          You don't need it lol
          2005 BMW ///M3
          Black6MT Daily
            Thoughts on ceramic coating?
            Old, not obsolete.
              Maybe a high heat temp paint would be a better recommendation?
                I wouldn’t want to add anything to the headers that would cause them to operate outside the manufacturers standards. If im not mistaking, ceramic coats and heat wraps make the headers internal temp hotter. How hot can they get before they deteriorate in some fashion? I’d rather not find out
                  Many are glorified paint but still do look nice. Need to get the good stuff that goes on a fair bit thicker for proper thermal management e.g. swaintech
                    I don't understand why people have the desire to waste their money on stuff like this.
                      Seems like a good way to keep moisture close to the pipes so they get nice and rusty
                        They'll also be great at absorbing (inevitably spilled) engine oil and setting your car on fire once the headers get up to temp
                          Ceramic coating covers the inside and outside of the pipe keeping the metal of the header cooler and carrying heat further back out the exhaust. Keeping under bonnet temps cooler. Ceramic coating is a winner. Wrapping in heat tape is bad. Its not a new concept.
                            I had my Euro headers ceramic coated. Definitely better than header wrap which will eventually fall apart.
ID:	135738 Click image for larger version
                            2007 GX470
                            build/journal
                            ig: @zzyzx85
                              Ceramic coats and wraps seem completely unnecessary. Snake oil, on the other hand, totally legit.
