Gearing up to install a set of SS V1 headers and catted section 1 in the coming weekends. Could use your guys' input as this the first header install I'll be doing.
1. Is there any need for a sealant / exhaust paste in the slip-on joint between the headers and the section 1? Worried that applying a paste there may cause the contanimation in the 02 sensors and cats.
2. Should the headers slip right into the section 1 without any force? And would you recommend installing the headers to the section 1 first, and then installing the combined headers+section into the car as one piece. Or to first install the headers and the install section 1?
3. What's the guidance on tightening the built-in section 1 clamps on the slip on joint? Just till some resistance is given / hand tight - or really wrench on it?
Thanks much!
Thanks much!
