Factory Rod Bolts Torqued Dry or Lubed?
    Originally posted by enjoy_m3 View Post
    lol.
    The purpose of the steps is to ensure the rod cap is aligned with the rod as accurately as possible. These are forged broken rods. You want to the rod cap to clamp on the rod with as much even distribution as possible. Otherwise, risk spinning the bearing on first start-up.
    Agreed, this discussion was around the impact or otherwise of lubrication on the result of the torquing procedure.
    I think we all agree that the end goal is a reliable, even clamping force.
      I've read to soak them in oil for 30 minutes. I believe it was Bentley or a copy of TIS that had been ported over to AllData at the time. This is was I did and it worked. I'm not sure why it said to soak the bolts in oil. Maybe someone can elaborate.
        lol.
        I'm not sure about this. The initial torque is not unique to rod cap -- the head bolts also use the initial torque and then add with the angle turns.
        We don't rely on the initial torque to align the crack-cap, but by visual.
          Wipe bolts with gasoline or brake parts cleaner, and lightly oil with motor oil just enough to make them shiny
