Best Bushings
    Best Bushings
    Doesn't seem there's a compiled list, and my hope is this will help to narrow it. The bushings listed below were ones promoted as best from multiple people, threads, and info contained here. I Will continue to edit and provide updates from good inputs.
    FCAB - OE, Turner Monoball
    RTAB - Dinan, CMP, SDW (Spherical)
    Engine - OE, BMW Grp N, RE
    Trans - OE, RE
    Subframe - CMP, Dinan, (Solid)
    DIff - OE
    Adjustable CA - BW, GC (Spherical)
    RSM - GC articulating
    I think it depends on application, whether it's destined for track use or mostly street. I've built mine under the category of "aggressive/sporty street" with the best handling with the least NVH. This is what I use and really like:
    FCAB: OE rubber
    RTAB: Turner sealed monoball (monoball seems to be the only bushing that allows the arm to articulate with the correct geometry without weird deflections)
    Engine: OE rubber
    Trans: Rogue Engineering rubber or OE rubber (edited: tbone pointed out the REs are rubber, not poly)
    Differential: 80A poly (Revshift)
    Subframe: 80A poly (Revshift)
      Rogue tranny bushes are rubber.
      best imo:
      oe motor
      re tranny
      oe fcab
      oe diff (tho I do like poly)
      solid alu subframe (cmp corrects height)
      rtab - sdw, dinan, fallline, turner spherical
      oe balljoints in rear hubs, oe rubber on the inside
      rsm - oe is fine for most (with plates). Akg spherical is very nice, but I wouldn't do spherical for most street cars.
        best imo:
        oe motor
        re tranny
        oe fcab
        The only one I have on this list is oe engine mounts 🤠
          Well you got some changes to make then.
            OE
            OE
            OE
            OE
            and OE
              Never. Possibly fcab but that about it.
                OE
                OE
                OE
                OE
                and OE
                I like your thinking
                  FCAB: OE / Z4M (off centered)
                  RTAB: Dinan/Bimmerworld .. anything spherical & sealed
                  Engine: OEM
                  Trans: OEM / Modified E21 mounts
                  Subframe: Solid Bimmerworld / CMP .. both correct geometry
                  Camber Arm: BimmerWorld Street & Track / anything sealed
                  Diff: Powerflex poly rear position, updated OE front position
                  My .02. In my opinion, deflection is key. Went down the rabbithole of changing every single bushing in my car to solid/spherical/poly a while ago and I just ended up making the car slower.
                    Just ordered some MSM street engine mounts to drop the engine 5mm. They recommend matching with Rogue Engineering trans mounts so that's what I'm doing. These mounts are 43A. Hopefully they do well.
                    I would HIGHLY recommend solid subframe bushings.
                      FCAB - OE, I have Turner poly currently but plan on going back to OE.
                      RTAB - Synchro Design
                      Engine - OE
                      Trans - OE
                      Subframe - Anything solid, PSM in my case.
                      DIff - OE
                        What's the reasoning behind the solid subframe bushing recommendations? Is it to reduce any possible movement in the subframe to theoretically prevent floor cracking? I feel like poly is a good choice for NVH and was curious if there was something I wasn't understanding.
                          Poly is never a good choice for anything.
                            I respectfully disagree with this. I think you definitely want be careful using poly in a suspension setup to not introduce unwanted geometry / deflections, but using it as a cushioning device between two relatively static components seems fine to me. What would you consider downsides to using poly for subframe and differential? IMO those usages are solely to absorb noise and vibration, but let me know if there's another variable I'm not considering.
                              I’m an OE guy as well.
                              However, I’m about to go with Black Series engine and transmission mounts on my S55 and one of my more experienced mechanics says he adds just a touch of poly to them to help them last longer. So there may be something to different poly formulations for longevity.
                              I’m not sure if poly can be added to mounts for this car but maybe I’ll ask him since he also owns an E36M (to go with 55s, 500E and pre-merger AMG cars).
                              maw
