Getting Torque Wrench on diff Bolts?
    not aware of anyone using these yet. i think you’re going to be the experiment.
    you should paint mark it and inspect
    I'll keep an eye on it, the larger washer would have been the way to go, I likely ended up in a wash (no pun).
    I put a washer on with less surface area than the original but with more "grip".
      ​Not a happy camper as i'm ending up here the hard way. Was all excited to have my rear end back in looking all fancy with full refreshed parts...only to find out i can't get a torque wrench on the rear diff bolts.
      ​I can actually get to front diff bolt just fine. This was because I removed the front bushing retainer so I could hand tighten the bolt on initially. All went smoothly there. So you all may just consider doing that as it's easy.
      But the rear bolts, no chance I can get a wrench in there, much less a torque angle gauge...
      ​​Click image for larger version
      Mother effer man....
      So my options are to drop the buttoned up new e-brake lines and rtabs....carefully lower the subframe enough to get to the rear bolts, and hope that's stable enough to torque the rears.
      ooor...
      just use a socket cap with a box wrench and some loctite and send it...
      🔹 2001 M3 Laguna Seca Blue
      Instagram: link
      Build thread: link
        socket cap and send it.
          concur with this method
            Nothing wrong with the socket cap method, just feel it out for initial torque and paint mark for approximate angle, it will be fine.
            I found a piece of pipe from a rolling jack that could slide over the box end wrench l, this made the angle portion fairly easy, I have the same CMP bushes as you do.
              Really appreciate it guys. Will use the socket cap and report back.
              One question about the nord-lock washer. My front bolt threads are just fine afaik, I hand-threaded the bolt on without issue, will use loctite then torque to spec.
              -Is the washer necessary? Are bolts really backing out on diffs that don't have thread issues.
              -Sounds like the smaller diameter one is working fine? or would you all go with the enlarged version if doing it again?​​
              Instagram: link
              Build thread: link
                I haven't checked the front bolt since torqued, if done again I would use the larger one for sure, didn't know it was an option.
                I have the car up on the lift currently, I'll check to see if the bolt is still torqued a report back if there's an issue. I would just give it a dab of blue loctite and you'll likely be fine in all honesty.
                  I'll go ahead and put a torque mark and keep an eye on it. Thanks.
                  Instagram: link
                  Build thread: link
                    Its the head of your ratchet... its huge. I have a couple different ratchets/torque wrenches and they are tight, but fit.
                    I've also found some sockets are longer than others, this one is a snap-on, fyi.
                    Email to [email protected]
                      This is definitely a huge variable and great point, I'll see if I can get my techangle up there with the CMP's and test some bluepoint and snap on sockets with it.
                      I hate not being able to properly torque it (in place) with CMP's, but those bushes are pretty nice overall.
                        This car doesn't have plates, it is stock rubber bushings as well, so should be similar (same) as CMP bushings and plates
                          Do you also have the solid cmp subframe bushings? Your photo looks like there is way more clearance than I have on my car.
                          Couldn't find stubby etorx sockets. I've thought about just getting regular bolts from mcmaster for this reason.
                            You probably didn't see my reply, but this is no plates and original bushings. But I have used this socket and torque wrench or (my Matco ratchet) exclusively for a decade+ and never had one I couldn't torque.
                              With the CMP bushings things are much tougher. I 'm not sure there is a socket and torque wrench that will do it. Let us know if it works out for you cubie
                                I've got CMP subframe bushings and managed to torque those bolts recently. Used a CDI 3/8" torque wrench and some random etorx socket that I cut down with an angle grinder. For the angle, I paint marked the bolts and then eyeballed it.
