Karbonius Carbon Fibre Stock S54 Plenum
    For the weight weenies the Carbon box will also save about 5 lbs. Stock box plastic is very thick.
    Youtube DIYs and more
      I weighed mine and it is about 8Lb lighter than the stock plenum. The Eventuri is another 2Lb lighter than the standard air filter housing, so 10Lb all up.
        CSL airboxes don't really have any issues if you do them correctly (CSL DME firmware, MAP sensor and tune for your specific setup)
        Exactly what I did, but I ended up with a blown engine to show for the troubles. Wasn’t tuned on a dyno, but engine was entirely stock otherwise and used proper CSL DME with h-bridge and MAP. The tuner supposedly adjusted tune accordingly (i.e., for US headers and no CSL cams).
        Also impossible to pass NY annual inspection which was a huge headache for me, may not impact others.
          I'm sorry that happened to you but let's be honest, how many others has this happened to? It's like 1 in 5,000? Whether your tuner is reputable or not, it should be easy to confirm if the car is running well afterwards before you redline the crap out of it - you should be able to do that yourself with free software. This shouldn't be a factor here at all...
            Completely forgot about the “import duty” fee through DHL…
              50 is nothing, it was 400 for me!!! US guys are so lucky
                Hey you're in Charlotte? I'm about an hour north of you. Would love to see that airbox sometime if you get it installed.
                  That is 25% of the Karbonius box...😲
                  Sure! Might be awhile but i'm planning on installing the Karbonius box first and then install the Eventuri.
                    Will have to see what people have done to their oil dipsticks but it’s here. Going to install either the Eventuri or Karb box first.
                    Click image for larger version  Name:	EA15B197-7158-44EC-B985-F1D867083AE3.jpg Views:	0 Size:	173.7 KB ID:	197064
                    Click image for larger version  Name:	EF6F11D3-A2E8-4072-ACB8-6458AD3AE115.jpg Views:	0 Size:	159.3 KB ID:	197061 Click image for larger version  Name:	00347E81-F85A-4EA2-BC4D-0BD5F55E1FB7.jpg Views:	0 Size:	211.5 KB ID:	197062
                      Click image for larger version  Name:	4918EAA1-7EAE-470F-B38A-704E5E1D5706.jpg Views:	7 Size:	180.3 KB ID:	197065
                      I'd recommend eventuri first - once you install the Karb box, you won't have a chance to test eventuri only for comparison reasons unless you remove the Karb box and re-install it again which is a decent amount of work... instead, you can easily swap the eventuri/stock intake....
                        I bent my dipstick to the right and made a basic bracket out of random aluminum to hold it to the airbox.
                          I kept my CSL dipstick, but the Z4M has so much more room
                            Quick audio clip of the intake with a 6" pod filter and a MAF setup I printed, OEM elbow. Took this with a Hero 8 taped between the SMG fluid reservoir and the fender. Figured some people might find this interesting.
                            EDIT:
                            Made a new revision of my printed intake that really let the intake sing IMO.
                            Thinner walls so less sound dampening.
                            FINAL EDIT:
                            1/20
                            Printed from carbon fiber fill polycarbonate and made available on 3dwardprinting.com for ordering.
                            The CF fill helped make the print so much nicer and the sound a bit louder yet. Pricy but worth it.
                              That sounds pretty darn good!
                                Designed a super basic bracket for the oil dipstick, because my aluminum screwed together L brackets unscrewed from all the vibrations and started clanging against each other every once in a while. Super annoying!
                                I hosted the file on my site listing for folks with a printer. Not super motivated to print these out for people because of how small they are and how basic the design is, but can do so for anyone needing one.
