Have you said anywhere in the thread what tyres you are running? I have run eyeball alignments which were way off on toe and camber with square 265 and pretty much no tramlining. I don't buy that a fractional difference in camber left to right is what's giving you your problem. Factory toe in as you have it set should be reducing tramlining. Only thing I can think is cheap tyres. The only time I've ever had problems with tramlining is when running cheap chinese tyres on the front temporarily.
For reference i'm currently running 255/40 square MPS4S with a track alignment (3.5deg negative camber on the front, toed out front and 0 toe rear) and I get zero tramlining unless it's quite wet and I'm going over standing water.
