Widened Carbon Fenders & CSL Bumper
    I just posted a new entry on my build journal here document the new wheel fitment possibilities.
    I've also set up a 5x limited pre-order special for Black Friday here.
ID:	241008 Click image for larger version
      Car looks amazing!
        I think you can fit a 12" rim in there using certain people's definition of fit bro.
          10.5”*
            Ahah - I can see some trying for sure. I'll be happy fitting a 10" with mild camber spacers, un-cut fenders, and a slight stretch.
              Progressing on the CSL bumper final fitment and its auxiliaries.
              1. The snorkel grill and inlet tube were successfully test fitted.
              2. The reservoir relocation from Brey Krause was fitted.
              3. The ASA bolt was threaded through the aluminum shock absorber in preparation for final fitment.
              The splitters have not be drilled yet, and we need to repair the corner threaded insert that got previously damaged for unknown reasons.
              The fenders and bumper will be bundled into a +/- 20% special for Black Friday over next weekend.
              Click image for larger version  Name:	_DSC6079.jpg Views:	0 Size:	243.2 KB ID:	242659
              Click image for larger version  Name:	_DSC6074.jpg Views:	0 Size:	103.4 KB ID:	242662
              Click image for larger version  Name:	_DSC6070.jpg Views:	0 Size:	97.8 KB ID:	242661
              Click image for larger version  Name:	_DSC6068.jpg Views:	0 Size:	76.1 KB ID:	242660
              Click image for larger version  Name:	_DSC6065.jpg Views:	0 Size:	125.1 KB ID:	242658
              Click image for larger version  Name:	_DSC6054.jpg Views:	0 Size:	100.1 KB ID:	242657
                Bruh I can't wait until you rid the car of those terrible wheels.
                For some reason didn't realize these were two separate thread.
                  100% - they're Baghdad spec wheels 😂
                  Yea, I figured I'd update each product threads with specifics - lots of little things coming together that I can't really touch on in the bigger build thread, it'd be a snoozefest.
                    Success - urgh not really.
                    Swapped the tires to the CS/ZCP only to find the beads were damaged off the Chinese tires. Still, I test fitted the +30mm spacers - we aren't quite there yet.
                    I tested these specs with 2x ride heights.
                    • 19x9.5J ET -7 (yes, minus).
                    • 255/35
                    • approx -3.0
                    • I slightly raised the KW CS by 5mm.
                    The tire is too thick, not enough camber, too low still.​ I will revisit this once the forged 163M style are here.
                    • I updated the entry here.
                    • A set can be spec'ed here in standard white gel coat.
                    • I can now import these fenders into Canada duty-free, get them prep'ed, primed and color matched before being delivered as part of the Bespoke Paint Program. Send me a DM or contact me.
                      Bruh you need 50mm of positive offset.
                      The deflated tire was a nice touch *chef's kiss*.
