DIY: Header Installation
    There is a spot on the Euro Sec. 1 for the EGT sensor, not on the headers themselves though.
    Correct, so am I able to run a US Sec 1 with euro headers without welding in a bung for the EGT or is the EGT required.
    Build Thread
      EGT is not required, especially if you are not running cats. My understanding is the EGT sensor is there to protect the cats more than anything, in fact that may be it's sole purpose. Someone correct me if I am wrong on this. Just use Martyn's software to code out the post cat o2 sensors/EGT.
        Cool. I plan on using Hassan and getting a true tune to optimize it. Maybe it’ll be smarter to use Martyns software to code it out while I go through RB break in (assuming the consensus is we need one).
        Currently, the plan is rod bearings and headers all at once. I’m guessing Hassan will want the whole power band so I’ll need to be through any break in, if there is one, before the tune.
        Build Thread
          What do you mean you left the EGT sensor plugged in? I’m under the impression there isn’t a bung for it I’m the euro design.
          Sorry I didn’t word that right. I meant I left the egt wire plugged in, but the sensor itself is just zip tied and set aside
          ’03 Oxford Green M3 (Turbo’d)
            Correct. EGT can be removed with euro headers and OEM sec. 1. This is what if did
              I’m in the middle of prepping for my install on Saturday. I didn’t see a ton of info on the corks but here is what I used, I picked them up at Lowe’s. I moved my expansion tank over towards the air intake, but left the semi-hard line that runs along the front of the car attached. It’s flexible enough to be moved out of the way without disconnecting.
              Build Thread
                Just about the best way to do it. Headers without the engine mount in place is almost a joy. Good luck!
                  Does anyone have a link to a good EGT bung cap? I am running CPI stepped headers with the EGT and pre-cat sensors plugged in and caps on the post-cat bungs, and just installed euro section 1 with the post-cat sensors but the EGT bung is open. I need a quick way to plug the open hole.
                    There is a bmw part you could order. I sacrificed an old egt sensor and made my own.
                      Planning on tackling my header install this weekend. This looks like it might be a bit tough. Wish me luck
                        Triple check that your gaskets are in place properly, especially if you're doing it alone. I thought I was wrapping up my install, found this just now once everything was pretty much back together
                          Damn that sucks. I feel for you man.
                            The DIY is way over dramatic. It's not that bad. Removing the catted headers are more of a pain than the catless ones though.
                            Dang man.
                            🔹 2001 M3 Laguna Seca Blue
                            Instagram: link
                            Build thread: link
                              A *small* dab of RTV can help keep the gaskets in place so they don't fall down.
                                Well that wasn't as bad as I thought it would be to get the gasket in place properly. I had to remove the exhaust nuts on the front header (obviously) along with header to section 1 bolts, and just loosen those section 1 bolts on the rear header. I was afraid I might have remove the section 1 completely, but it was no problem.
                                I bought new Elring gaskets to use for the install, but those came apart a bit upon removal, so I've got the Megan gaskets on the front header. They're way thicker and I haven't read great things about them, they were fine on initial startup though.
                                As far as tips, one thing that would have saved me an hour or two of struggling was if I knew that the section 1 had to be removed completely to get the stock catted headers out. Either I missed it in the guides or it wasn't specified, but I thought I could leave the section 1 in place to keep from having to deal with the section 1 to 2 bolts and gaskets. Once I removed the section 1, the headers came out from underneath relatively easily.
                                I struggled more with the heat shields than I should have as well, especially on reinstall. I recommend getting them both roughly in place before attaching either one. On the first reinstall I put the frame rail one on first, and I was able to finally get the engine one in place, but it was way harder than it should have been.
                                On the EGT sensor, I was going to keep this but I ended up removing it instead. I had enough cable length to reach with the Megan headers, but not enough slack to really route or secure it properly. I've seen it mentioned before on here, but the thread size is M14-1.5, which is a popular lug nut size. A Toyota lug nut fit mine great, and I added a copper washer from a generic assortment to try and work as a crush washer.
