Originally posted by Subfra///Me
Alternator Options
Just looking at the available Valeo parts myself as mine is struggling to break into the 13V range. The Bimmerworld page claims they are selling the brand new Valeo unit, but the part # they list suggests it's a reman. I've had bad luck with Rock Auto parts in the past.Originally posted by Subfra///Me View PostFantastic info! Thank you!
I just confirmed on the Valeo link you provided. Interesting that the Bimmerworld part number is actually a Re-Gen and the unit from Rock Auto is an Origins and cheaper.
The voltage regulator wears out over time and might be causing the low voltage. They should be less than 100 bucks.Originally posted by nahvkolaj View Post
Just looking at the available Valeo parts myself as mine is struggling to break into the 13V range. The Bimmerworld page claims they are selling the brand new Valeo unit, but the part # they list suggests it's a reman. I've had bad luck with Rock Auto parts in the past.Last edited by Slideways; 07-20-2023, 10:36 PM.
Yeah the OEM Valeo regulator (made in Poland) is $79 and Genuine BMW regulator is $149 (from FCP).Originally posted by Slideways View PostThe voltage regulator wears out over time and might be causing the low voltage. They are should be less than 100 bucks.
Installed the 140amp X5 alternator. Perfect. Thanks whoissuprmeLast edited by 0-60motorsports; 07-24-2023, 11:05 PM.
- Likes 4
Mid the connector shape is the same my understanding is you can use them. People are also using e53 X5 alternators. The 140amp one, fwiw.Originally posted by sapote View PostSorry if this had been discussed before: what is the reason why we can't use any Valeo or Bosch 120A alternator with square 2pin connector from the non-M car? If mechanically they fit to the M3 then I don't see the reason why we can't use them.
I tested fitted my 330i alternator. Fit fine and connected but I never tried it as the motor was out of the car.
