If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Funny you post this because I parked my car in the sun on a hot day for about 3 hours and came back to a bunch of dead pixels.. These cars are starting to show their age. Yes you can swap the screens but from what I have read, its not a project you want to attempt yourself. I am going to ship mine out to be professionally swapped.
2007 Imola Red Z4M Coupe
Is there a reputable vendor that completes these swaps regularly?
I swapped mine fairly recent. Just need a nice precision screwdriver. Some folks said that they needed to adjust the screen position, but mine was spot on from the factory.
Yeah, mine has been perfect up until this spring when I started the car.
Take your time/be careful with all the ribbon cables, its not hard just remove and replace. Also like Epsilonsaid, make sure the screen is centered properly because you cannot adjust once it is back together.
BTW this is the one I bought
USA Ship - LCD screen Display panel Sharp LQ065T9BR51 for BMW E38 E39 E46 E53 X5
Reason: added part #
I remember a more comprehensive one that I cant seem to find now. I think I may have watched this one thinking the E46 unit was the same as X5 and E39? it looks different on the back but I thought they were all the same MKIV unit https://www.youtube.com/watch?v=zhCnLbcl5m0
Looking to get my screen replaced, has anyone used ether of these two companies?
https://www.germanaudiotech.com/products/lcd-replacement-service-for-bmw-e46-325-328-330-m3-16-9-wide-screen-navigation-monitor
https://www.bavtekinc.com/bmw-widescreen-16-9-navigation-display-lcd-repair-e46/
Any good? Any others out there I
The guy skipped a lot of minor in between steps in the videos, but fortunately, they are self-intuitive with a little exploration. I did buy a broken unit to experiment on before making the commitment on my actual unit.
Also, don't use a multi-bit precision screw driver set. The magnetic head is too big to insert into the deeper narrow holes.
