Bosch style injectors leaking
    My car has been in the shop going on close to two months now.
    I had them put on a smaller pulley on my supercharger, and swap my injectors and fuel pump for bigger units. ID1050x to be exact.
    They haven't been able to get my injectors to seal properly yet. At first, they weren't sealing at all. So they sent the adapters to a machine shop and had them enlarge them. Then the injectors sealed enough to pass a smoke test, but they are now leaking at around 6 PSI of boost on the dyno.
    I don't want to go back to my Dinan 440s.
    Is there a trick to running EV14 injectors in our cars? I've googled and am not coming up with much.
    I saw someone mention running a washer under the rail to space it up, but my tuner said that didn't work.
    2004 Dinan S3-R M3
    2023 X3M Competition
    Nobody running these?
    2004 Dinan S3-R M3
      Search, there's a thread or 2 (one might be in tuning section) about injectors.
        thegenius46m is using a Radium fuel rail and it solved his sealing issues. Maybe test one out.
        Instagram: @logicalconclusion
          thegenius46m is using a Radium fuel rail and it solved his sealing issues. Maybe that out.
          Thanks! I actually just ordered one hoping that'd fix it. Here's hoping for the best!
          2004 Dinan S3-R M3
            What's the issue? Are the injectors being torqued at a weird angle by the rail or are they sitting too low into the throttle bodies?
            2003 E46 M3 TiAg/Cinnamon 6MT
            2005 E46 330i ZHP Imola/Sand
            Instagram:@thegenius46m
              I believe they are sitting too low
              2004 Dinan S3-R M3
                Hmm mine didnt do that when they sat too low. Sure the o-rings aren't compromised? They'll warp pretty easily if you have to jam them in at an angle
                  Injector Dynamics has sent two different sets of O rings actually
                  2004 Dinan S3-R M3
                    This is what happens when you fit the EV14s in without spacers between them and the throttle bodies.
                    With spacers, excuse the crap picture.
                      so something like this?
                      ‘02 LSB M3 (11k original miles)
                      ’03 Oxford Green M3 (Turbo’d)
                        Yup, those would do the trick. You'll need to tweak the fuel rail and feed setup slightly as it'll raise the injectors and rail up.
                          Can you elaborate on this?
                          The Radium fuel rail did not fix my issue, I was still getting a boost leak at 6 psi. They put my old Dinan injectors back in and it held 11 PSI fine.
                          2004 Dinan S3-R M3
                            It's probably not applicable if you have a radium rail to be honest, but for the stock rail you need to do this:
                            Remove the captive nut from the rail and enlarge the hole to give you a bit more wiggle room for the taller injectors.
                            Then slacken off the 2 bolts highlighted and pull the fuel feed up and re-tighten the bolts. I added a small spacer behind the tab on the upper bolt to allow it to move upwards a little more.
                              Did you ever come up with a solution? I’m having the same issue when I installed FIC 1000cc injectors. All 6 leak boost instantly and I can’t even hold 1psi.
