What’s the OEM RACP part number
    That was fast! Great work
      I am not working until November so it helps
        Believe it’s 41 11 7 000 246
        welp, another part that's gone NLA.
        Man oh man, this sucks.
          That one is not cool… More part out cars in the future
            I would like to get some help if possible, regarding removing racp. I got confused at the end of removal process. #gt4 i think maybe you can help me with advice
              Confuses me, the individual RTAB pockets were gone for a while and randomly came back in stock a few months later.
              Sucks for people having to restore ones that are 'beyond saving' but could still be saved with a new panel, removing a used panel in a way that it can be reinstalled really sucks.
                Hopefully all we are seeing is a more obvious shift to batched spare parts production, so things go in and out of backorder/NLA. This happened on the rear axles, then the part numbers indexed after going back into production.
                  Check on Youtube for Redish RACP replacement videos. They have like 7 videoson the same car where they replace the whole RACP
                    Yep I'm hopeful this is what it is - I've been accumulating parts for some time and have seen a number of parts go from supposedly NLA to being in stock again.
                      I can't find those? Do you have a link?
                      Awesome work GT, I just found this!, Been searching and reading every RACP thread i can find over the 3 forums
                      i am preparing to replace mine at the moment just like you did, hopefully your in a position to answer questions
                        Still NLA, hopefully returns soon
                        Surely we can find NOS?
                          When I bought mine in January 2023, I was told there was 2 left only for North America.
                          Pretty sure it's going to stay NLA
                            I think their is part #1 to part #7 videos
                              Hey GT, How did you remove the spot welds ?
                              I found a donor car for the RACP
Name:	RACP DONOR.jpg
                                Click image for larger version  Name:	RACP DONOR.jpg Views:	0 Size:	86.4 KB ID:	330415
                                You need a spot weld drill bit and a spot weld chisel to separate the layers.
                                Also, check post #11 of this thread. You don't need to transfer the rear trailing arm pockets. But you would need a jig to reinstall the "new" panel and make sure it's perfectly align. I can sell my jig but shipping to Austalia would be crazy expensive!
                                The jig would also help with the install cause you can hold it on the car bolted in the RTA pockets and than put jack stand under the jig and use the weight of the car to put pressure so the RACP has no gap with chassis while welding
