Comprehensive Steering Information Thread
    I hadn’t (that day job thing got in the way the last few months) but I’ll open it up next week. I have a rack rebuild for a 712 pending so it will be a good time to lay the two out with measurements.
    TBD!
    Oh shit, I forgot to send you my old ZHP rack 😭
    997.1 GT3 Carrara White/Black
    C43 AMG Diamond Silver/Red​
      I’ll be opening up a CSL/ZCP 924 rack and comparing the guts to a ZHP 712 rack within the next week or so.
      David
      I’m very curious on this…I have a ZCP rack that is likely in need of a rebuild
      I’ve considered purchasing a ZHP rack…I’ve driven a handful of E46s with ZHP racks however, and I’ve always preferred the ZCP rack. Curious if there’s anything quantifiable, or if it’s a placebo.
        I think there would be too many other variables to make an accurate judgement unless it was on the same car. Does the non-M has different caster angles? But track width, tires, wheel offsets, suspension could also affect feel...I would think.
          Figured I'd give my feedback after shimming the PS pump. Thanks to Volke and anyone who contributed, and thanks to bigjae for supplying the washers.
          So I have an E90 m3 that has unbelieveably good steering feel and weight. After having an E36 325i with fantastic steering, I was always a bit disappointed when I moved up to the E46 M3. It has very good steering, but the feel was always "springy" and light to me.
          After getting the E90, it just got exposed that much more, so I've been wanting to match them up as much as possible. I've already done things like wider wheels/tires up front for a"heavier" feel, but that didn't have a lot of impact. A Yellow tag rack didn't do anything either really.
          I was hopefull shimming the pump would be the ticket. So the job isn't too bad, but you definitely need a good method for getting the valve out - I used magnets.
          I started with 2 .5mm shims for reported 25% reduction in boost. I lost most of the fluid, so it got a good flush. Ok so how does it feel.? First, it did work, there is less boost, BUT it feels to me a bit progressive where the wheel is still very light and bouncy (snaps back to center quickly) but then starts to get stiffer as you turn.
          The E90's wheel is super stiff 100% of the time. If you turn the wheel a little and let go, it doesn't snap back to center nearly as fast as the E46. It feels equally stiff no matter what amount of rotation you give it or at whatever speed. The E46's wheel now only really feels stiffer when you have more rotation.
          So there must be something else involved. Both cars have 265 tires & 9.5" lightwieght 18" wheels. Similar high end suspension and spring rates. All factory parts when it comes to steering and front end bushings (except for plates in E46).
          All in all, I'm happy to make the steering stiffer for such little money and time/effort, but it's bittersweet because it's not stiff right from the off. It still has its light and springy nature I was hoping to eliminate.
            I'll have to pay more attention next time I drive my car. But that makes sense. The PS assist should be about the same until the RPMs get high enough to open the pressure valve which would be lower with the shims. Maybe if the pump was overdriven, then the pump could reach that point at lower RPMs but that would do the opposite of an underdrive pulley.
              If you’re running offsets below et45 or so, this could partially explain it. The e9x has a virtual pivot to control keeping scrub radius smaller, which allows it to run low offset front wheels. A smaller scrub radius means that you’re pivoting the tire closer to its center, fighting it less as you turn more.
              If you want to bring feedback closer to the e90 and a bit more linear, you’ll want the CSL rack (claimed stiffer torque bar internally) and/or less pump assist and an offset around stock e46 M3, not something like et35 like most folks seem to run. You may also want to eliminate the rubber steering guibo or go with a shorter ratio, as the e9x has an equivalent ratio of 13.3:1 when you adjust for wheelbase differences. The non-m e46 is 13.7:1, CSL/yellow is 14.5:1
              Any and all of those should help. High offset wheels is the easiest.
              edit: you will never be able to 100% recreate the e9x steering feel in an e46, because the e46 has a fixed kingpin axis, where the e90 has a kingpin axis that moves. When you turn the wheels in an e46, the wheel and tire move somewhat forward and backward in the wheel well. Because the e9x has a two-link lower and a virtual pivot point, the wheel doesn’t move forward/backward in the wheel well much at all. The force to push the outer tire forward when turning is generated from the steering wheel. I think this is the only thing you can’t recreate though, and just a portion of the total effort.
                One more thing: the e9x has a way stiffer front chassis. Very big difference there. But more expensive to fix
                  Thanks for that background info Bryson.
                  I run 9.5"et35 front wheels but have to use, at minimum, a 5mm spacer for the 996 capilers. So I'm locked at offset of 30. Even with a different profile wheel, I doubt I could go much higher.
                  I'll keep my eye open for CSL/ZCP rack, that's probably the last reasonable thing I'd try.
                    The e9x front end grip is magical BUT I've got my E46 close with some good mods. I'm not terribly bothered by how good the front end of the e90 is versus E46. The gap in steering feel is much bigger to me.
                      I run 9” ARC-8s with et46 (et52+6mm spacers) and 996 calipers, so it can be done! Just have to be real creative.
                      The front end stiffness has a huge effect on steering feel and especially precision. This is the primary reason I went so far to stiffen the front end with the Slon brace - steering feel/precision/feedback. I actually find my e46 to be much more fun with better feedback than the e92 personally. I run a rebuilt yellow tag rack, 9” et46 wheels, solid steering shaft, 245 front tires, Slon strut brace. You’re welcome to take it for a spin if we ever get to meet in person. I’ll be moving to San Diego soon.
                        I don't see how that's possbile - the 996 big reds are huge! Maybe the different spoke profile or did you scallop them out further? Or mill down excessive alloy material on the calipers' outside :P
                        That would be interesting to test, thanks for offering.
                          Here ya go! Just under 3mm clearance, no machining (other than the standard machining to fit) required. These are 17” diameter too, even tighter
                            I've driven Bryson's car with the brace and the difference is huge. Had a passenger ride with me the first time I drove it (who's not into cars in the slightest) and even they said they noticed a difference between my car and the wagon.
                            My triangulation brace design will be open sourced when finished! Only costs will be manufacturing, hardware, adhesive and a set of E85/E86 braces. Say $1-2k all in.
                              Just read through this whole thread.
                              Maybe I've missed something, but is there a rack that doesn't have a big dead spot on center? Never had a car with steering that was both vague and nervous at the same time...until now 😆
                              It's like you're whipping the steering wheel around too easily on center, but don't notice that it's too easy because it's dead. And then it suddenly breaks out of the dead zone and gets nervous. Is this how they all are??
                              I've done the Z3 rack thing before, on an e36 M3, and it was indeed way too twitchy for me. In fact it was one of only two mods I would not have done over again (and won't do with this car).
                              I have the pump regulator spacers coming. Hopefully that will correct the over-assist issue. But what about the on-center response? Are any of these rack options more responsive in the middle without being spastic?
                                Some suggest a solid steering joint rather than our rubber ones. I installed a new factory one not too many miles ago and it helped, but I may try solid.
