Hello Group,
I am installing 6 piston Brembo’s in the front and need help finding the smallest spacer size to clear the brakes.
Wheel size is 19 x 8.5 ET44 on Indy 500 Firehawks tires 255/35/R19. The tires are a lot wider than OE spec and I plan to swap out all 4 tires for MPS4’s Spring/Summer of 2023. Hoping to save some money and get my BBK installed with the wheel/tire setup as is.
If anyone knows the minimum clearance required to clear Brembo’s for the front given my wheel size and offset, please let me know. I’m on stock suspension / ride height at the moment with stock camber and alignment. My car will be getting alignment done this week so it’s the perfect time for me to play around with the negative camber within my stock limits.
Thanks in advance
Thanks in advance
