Valve bent, piston indents... :-(
    Hey Guys,
    So I have two bent exhaust valves and they hit the top of the piston (cyl 6). This happened when going through timing/cam install (engine out of car). Pics are below but want to ask...
    1.) Will the valve indents effect compression? Currently I'm at 190 all 6 cylinders before this incident.
    2.) Will removing/reinstalling the head effect compression?
    Ordering two exhaust valves now. .
    Thanks,
    Kareem
    Additional pics before head uninstall
      Won’t affect compression, I’d smooth out marks to minimise hot spots.
      None of them are direct above ring groove and might have pinched a ring ?
        You made these dents while turning it over by hand?
        im in the middle of reassembling mine now, so any tips are helpful. And I’m sry this happened - bummer!
          Yeah.
          I forgot that turn the cams while keeping the TDC pin in means the bottom is lock, but the tip is moving. Therefor the valves will touch the Pistons that are up.
            Will do, thanks for the input.
            Any suggestions on how?
              It's really hard to make such mistake as you feel resistance when the pistons touches the valve.
              I think you should have a professional assemble the engine for you to avoid further damage.
                When you remove the bent valves take a close look at the valve guides on the intake/exhaust port sides. The valve guides could easily be cracked/broken by something like this.
                  It was more on initial torque down of cams. I felt resistance, but I was working through cam binding... so thought the resistance was due to this.
                    Will do.
                    The marks I'm fine with... I'm just worried that the perfect compression in now ruined (with piston marks and new valves).
                      I can see that happening, especially if you use a large wrench you might not realize how much pressure you are working with and with the springs pushing on the cam you might think that is what you are feeling.
                      However, I still can't see how the cam was jammed in the first place when you initially removed the cam without ruining the journal or cam. Also, there shouldn't be any binding upon reassembly. If there is, the cam or journal is likely damaged.
                        do a leakdown test to see if there's any leaks on the valve seats. If leak down test is good, then consider yourself lucky.
                          Piston #1 was fine? 1 and 6 follow same timing i do believe.
                            Yes, all other cylinders are fine.
                              Pistons go up/down at the same time but cam timing is offset 180 deg IIRC
                              If OP was only installing the exhaust cam when this happened, I do not expect there to be damage on other cylinders.
