Originally posted by HanSooloo
S54 Dyno Database
Actually 46 whp gain from stock with the airbox, SSV1s and PCS dyno tune.
Wow … even more impressive.Originally posted by heinzboehmer View Post
Stock!
So, just Super Sprint + CSL air box = around net 30 HP bump. Is that how we should read it?
Wonder what you would get if you had Schrick 280/272?
That’s going to be my setup :-)
Stock!Originally posted by HanSooloo View Post
Really impressive numbers. What camshafts are you running?
Really impressive numbers. What camshafts are you running?Originally posted by heinzboehmer View PostI know I said I was done chasing power (and I am!), but I have all this incremental dyno data and recently got lighter wheels (~6 lbs per corner), so I couldn't help myself. Was back at the dyno this morning to see what effect they had on the whp.
Updated setup:- 130000 mI
- US spec pre-facelift M3
- Karbonius full carbon intake with carbon snorkel
- Kassel MAP
- Stock CSL IAT location and sensor
- HP converted MSS54
- SSV1s and SS oversized section 1 with HJS cats
- Stock section 2 and 3
- All engine maintenance done
- Rod bearings replaced ~17k mi ago
- VANOS done ~17k mi ago, passes VANOS test with no issues
- Engine retimed ~6k mi ago
- Valve adjustment done ~6k mi ago
- New front and rear TPSs ~2500 mi ago
- New precat O2 sensors ~1500 mi ago
- No mechanical fan, just aux
- Rogue engineering water pump and power steering pulleys
- Dynoed at Sonoma racetrack so altitude is ~sea level
- 52ºF ambient temp
- 90% (!) humidity
- Running Shell V-Power 91 octane
You also need to be logging ignition timing when comparing mods especially with small deltas as weather corrections won’t account for that
Yep! I agree. Next time I do an experiment like this I'll make sure to take all measurements during the same session.Originally posted by stash1 View Post^^^ I think that the lighter wheel results were def a result of the different days/weather conditions, because I've seen a few dyno's that showed just the opposite. I think that if you had swapped wheels back 'n forth during either session, there would've been a difference...albeit, a very small one (favoring the lighter wheels).
^^^ I think that the lighter wheel results were def a result of the different days/weather conditions, because I've seen a few dyno's that showed just the opposite. I think that if you had swapped wheels back 'n forth during either session, there would've been a difference...albeit, a very small one (favoring the lighter wheels).Last edited by stash1; 03-02-2022, 06:05 AM.
And just for fun, we ran a quick experiment. I had the operator do a run with the AC compressor off and then do another with it on immediately after.
Dyno graph comparing the run with AC off (red) vs the run with AC on (blue):
The runs were done at the very end of the session, so car was heat soaked by this point. Not an issue really, as I was just interested in the delta between the two.
And once again, yes you're reading that right, the car made more whp with the AC on.
Pretty interesting that you can see at which point the compressor becomes a real problem (~6.5k rpm). At around 7250 rpm, it seems like the DME disengages the clutch and the power jumps back up. I can't confirm that the clutch actually disengaged (since the airbox is so damn loud), but that's what it looks like from the plots.
So even though I didn't get the results I was expecting today, I did learn a couple things:- Comparing data from different days is basically meaningless. Even if most variables are controlled for (dyno, dyno operator, correction factors, car setup, etc.), the variance in conditions from one day to the next is enough to completely skew the numbers.
- The numbers themselves are pretty much meaningless too. There are just way too many variables that are constantly changing for this sort of measurement to be precise and repeatable. Numbers are nice for ballpark figures, but the shape of the curve and AFRs seem to be much more meaningful.
Updated setup:- 130000 mi
- Kassel MAP
- 52ºF ambient temp
- 90% (!) humidity
Dyno graph comparing the run with 19" wheels (blue) vs today's run with 18" wheels (red):
312 max WHP, 250 max WTQ
Yes, you're reading that right. The car made less power with the lighter wheels. Or maybe more accurately, the car made less power today than the last time I was at the dyno. Would not be surprised if the 90% humidity played a big role in it. I'll mess around with correction factors and all that to see what I can learn from these plots, but I think it's pretty clear that doing these sorts of comparisons in different conditions (even with the same dyno, same operator and same car setup) is not very meaningful.
One thing I don't love is the AFRs. Car is leaning out a lot at 7k rpm. The AFR curve looks pretty similar between the two runs, except that today's is shifter up. Maybe also related to humidity? Definitely not an equipment problem, as we swapped out the AFR probe's O2 sensor for a brand new one when we saw how lean it was measuring. I'll reach out to Paul to see what his thoughts are on this.Last edited by heinzboehmer; 03-01-2022, 12:53 PM.
^Understood, thanks guys! The only reason I thought of Steve is because his stuff used to be CA/Smog Legal, or at least you got the certs? but maybe not even worth the trouble and $$$$ if I can't legally drive it.
Nice numbers, congrats, and thanx for contributing to the thread!Originally posted by cali chase View PostFinally got the supercharged Z4mc back on the dyno after 5 years of work on the Frankenstein supercharger kit.
Thanks to the mss70 master Severn tuning really happy with the car as we now approach tune iteration 85.
12psi, e85, high rpm contoured Si trim impeller, stock pullies, id1050Xs, walbro 450, gigantic AtW heat exchanger
Car weighs in at 3125 full fluids (no driver), and is running low 8 60-130s and trapping mid 120s. Excited to get it back on track this fall for some sub 2:20s at Sebring.
video on my ig: _SB__Garage_
car made 308/280 when na with euro headers and a TTFS tune way back in the day.
Ha, yes, I saw that...but what you (and prolly most folks) don't realize is they're actually multiple ways to 'trick' an 'eddy current' type dyno. Weight is only 1 way, but weight doesn't typically have a huge affect on the numbers...especially for lower powered cars like our M3's. There are other 'multipliers' that can be changed as well, along w/the correct weather correction factors, tire strap tension, blah-blah-blah. So, again, that's why you can't just apply a random correction % to a Mustang number to arrive w/a comparable Dynojet number and vice-versa. Here's a quote from a random website where a customer's vehicle actually made more power on a Mustang vs. a Dynojet...this particular vehicle made approx. 15 more HP on the Mustang vs. the Dynojet-lol. This is the response from the tuner/operator:Originally posted by thegenius46m View Post
Yes actually. Runs were initially done at 2500lb load and the final run was raised to 3500lbs to make sure the tune was still safe on the road. Difference in power between the load changes was only 2hp which is pretty damn good when you factor in some heat soak.
Originally Posted by AWE-Tuning
Back in 2002, we changed multiple settings to get our Mustang AWD-500-SE to read more like a Dynojet, including settings that offset the curves higher than as-delivered, to settings that also change the weighting of the curves (shape) to mimic the Dynojet better. If you want all those figures, we're more than happy to share.
That was back in '02, and has since become even more common practice today. Again, because Mustang operators were losing business to Dynojet operators 'down the street' because their dyno's produced 'bigger' numbers...many of them have altered software to produce 'Dynojet' like numbers. I'm NOT trying to blow up your results man, just trying to educate-lol. Your car might make 20HP more on a Dynojet...it might make 20 HP less...or it might make about the same!? No way to know unless you strap it on a DJ.😉😁Last edited by stash1; 02-24-2022, 11:20 AM.
Yes actually. Runs were initially done at 2500lb load and the final run was raised to 3500lbs to make sure the tune was still safe on the road. Difference in power between the load changes was only 2hp which is pretty damn good when you factor in some heat soak.Originally posted by stash1 View Post
Right, like we always say, a dyno is simply a tool for testing/measuring one’s progress. A Mustang (load type dyno) is absotively the best type of dyno to use for tuning…because you can better simulate road conditions. However, it’s not necessarily the best for just generating numbers because of the built in variabilities.
Your dyno guy is correct in the fact that if you run a Mustang in a loaded state that it will generally produce figures lower than on a Dynojet. But again, that percentage is adjustable, and who knows how much load (if any) the operator has dialed in? Did he tell you, and would you or I understand it…even if he did? If the dyno was run in an unloaded state, then that would probably produce numbers that are actually higher than a Dynojet. My point is, you and I will never really know, and it doesn’t matter...as long as you go back to the same dyno every time, and the operator loads the same ‘calibration’, then that’s all one needs to worry about for tuning/testing.👌
Again, I’m no expert, but I know a little bit.😉 The dude in that link doesn’t know what he’s talking about btw—lol. Again, you can’t assign a random ‘correction’ percentage w/o knowing how a given dyno was set up. He’s assuming that the Mustang dyno in that example was being run in a fully loaded state (I'm assuming)…and I’m telling you, that’s rarely how most operators set them up.
EDIT: FAAAK, I hate posting from my phone, it’s a PITA!
- Likes 3
Right, like we always say, a dyno is simply a tool for testing/measuring one’s progress. A Mustang (load type dyno) is absotively the best type of dyno to use for tuning…because you can better simulate road conditions. However, it’s not necessarily the best for just generating numbers because of the built in variabilities.Originally posted by thegenius46m View Post
Funny my guy says the opposite that dynojet is the clout king because they almost always read higher. The mustang seems to simulate more real world scenarios as it is load and temperature based for the correction. But honestly they're all bs. You can't compare ANY of these directly to each other because there are too many variables that are not kept consistent between them all. Time of the year, altitude and pressure differences, calibration of the dyno, etc.
A dyno reading is nothing more than simply a DATAPOINT that you can't compare directly with someone else unless they run their car on the same dyno at the same shop right after yours so weather conditions are also the same. The best you can use the numbers are for is a reference.
I REALLY wish I had the luxury to have dyno'd my car before the headgasket blew but that simply wasn't an option. That would have been my direct comparison of the modifications.
BTW give this a read on the types of dynos. Interesting info for anyone wondering:
https://www.1addicts.com/forums/showthread.php?t=214597
EDIT: FAAAK, I hate posting from my phone, it’s a PITA!Last edited by stash1; 02-18-2022, 06:25 AM.
