S54 Dyno Database
  • stash1
    Originally posted by robgill View Post
    Recently got my street build on the RK-Tunes dyno for a custom Alpha-N tune. Mods:
    - Karbonious CSL airbox
    - 280 272 Cat cams
    - SuperSprint V1 Header, SS Catted section 1, SS oversized resonated section 2, SCZA muffler
    - TMS pulleys
    After Jordan doing his thing we ended up with 350 WHP & 261 Torque. Pretty happy with that.
    Nice build and results Rob! Thanx for posting man!
  • robgill
    - 280 272 Cat cams
    - TMS pulleys
    Click image for larger version  Name:	51072704238_4001c320e0_b.jpg Views:	0 Size:	202.1 KB ID:	94586
  • stash1
    Originally posted by Thonas View Post
    plugs had maybe 10k to 15K miles. Is there a guide to perform a VANOS test? can it be performed with the schawben scan tool? Thanks!!
    Plugs should be fine w/those low miles. I believe that a Schwaben will perform at least some of the tests, but not all? I've always used a GT1 type tool, but there are other means of running a VANOS test. Maybe search in the Coding/Tuning section for other recommendations.
  • Thonas
    Originally posted by stash1 View Post
    How many miles on your plugs? Might want to perform a VANOS test as well.
  • stash1
    Kassel thought it was plugs being a bit old. I replaced them but will not be able to get back to them for another run.
  • Thonas
    Why is it nosing over at 7,000rpms? Have you performed a VANOS test recently?
  • stash1
    So what should I do next for more NA HP? Is the next step cams?
  • Slideways
    Yep. Though, I think that the current setup is solid as is. The funds might be better spent on a few DEs or track days.
  • Thonas
ID:	92927 Click image for larger version
    Full Supersprint (Stepped headers, race cats, sport Muffler)
    Kassel MAP conversion, CSL Conversion
    Turner CSL air box
    Kassel dyno tune (mustang dyno)
  • Mspir3d
    Originally posted by SliM3 View Post
    Nice numbers man!! What BW turbo are you running? Turbo manifold?
    Thanks! It is a maxpsi e85 kit with Spa manifold and the BW 364.5 sx-e
  • SliM3
    Originally posted by Mspir3d View Post
    I’ll update mine, ~770 whp and 700 ft lbs. The BW maxed at 25psi, I’m planning on ordering a xona rotor hopefully. The afr was lower by .5 or so on the wideband in the car but still looking a little lean.
    Click image for larger version  Name:	88355299-AEB4-48C1-9FBD-FE18F22E236E.jpeg Views:	0 Size:	191.3 KB ID:	93531
  • stash1
    Those are some very srs numbers sir, thanx for posting!
  • stash1
    Turner CSL air box
    Congrats, nice gains, and thanx for posting!
  • Thonas
    Wow, those are some big numbers!! Your car certainly goes to 11
  • Mspir3d
