plugs had maybe 10k to 15K miles. Is there a guide to perform a VANOS test? can it be performed with the schawben scan tool? Thanks!!
Plugs should be fine w/those low miles. I believe that a Schwaben will perform at least some of the tests, but not all? I've always used a GT1 type tool, but there are other means of running a VANOS test. Maybe search in the Coding/Tuning section for other recommendations.
I’ll update mine, ~770 whp and 700 ft lbs. The BW maxed at 25psi, I’m planning on ordering a xona rotor hopefully. The afr was lower by .5 or so on the wideband in the car but still looking a little lean.
Nice numbers man!! What BW turbo are you running? Turbo manifold?
Those are some very srs numbers sir, thanx for posting!
Wow, those are some big numbers!! Your car certainly goes to 11
Thonas Congrats bro, really nice numbers. Excited to see your torque figures as I'll be going SS stepped and oversize dual throughout. Im at 325/250 whp/wtw on dynojet now (turner csl map, oe euro header, scza) , a little more oomph in the midrange never hurt anyone.
