S54 Dyno Database
^^^Thanx for the detailed post, and very nice results—congrats!
September 10, 2020.
Finally got my car ready, for the dyno tune with HassanEido HTE, also got some of my car group friends to join in. This is my first car, and def first dyno session. I completely forgot about more aux fans other than just the main large diameter fan, this def had an effect on results but here are my cars specs.- OEM Euro headers
- OEM US Sec 1 and 2
- SCZA Sec 3
- Turner Motorsports CSL Airbox
- Stock Differential
- Apex EC7r 18x9.5 / 265/35/18 RS4s
A couple more runs after this and Hassan lets me know that the intake temps are "toasty" and I forget we didnt not put in more aux fans, so I ask the shop/dyno owner for more. We all forgot not, fucking amateur hour.
Then the car started to creep up in power as temps were at least calmed down. No doubt it had an effect on the eventual outcome but still very very happy. The canned tune on my car before the CSL Map conversion was utter shit. Pronounced waves in power after 5.5k rpm at WOT, just awful. This was insane to me, that my car could feel this good.
The following runs.
And last set, best set.
Car runs better than ever. The tune was for 94 octane that is offered here by Petro Canada. Although I'm not sure of the quality of this rating. If any of you know of octane analysis websites I'd be happy to do more research. Shell 91 always tests well here. I'm insanely happy with the way it runs, it's crazy addictive to just keep your foot in it with this setup, masterpeice of a car/engine/chassis.
Hassan worked for about 5hours and a bit on all our cars. We had 3 cars on the dyno and were pressed for time due to some early setup complications on the shops part. We were cracking jokes, having fun, he worked tirelessly to get us the best possible in the time we had allotted. Much respect, and thank you.
Next year we go again
Hi James. Just getting round to replying - not got much time these days for forum input as i'm busy at my own dyno as well as other tuning projects. Great to see the positive report and was a pleasure to tune it for you. Low down AFR's still needed a bit more work although looking better and not hurting power. I find the SSV1 headers tend to cause these swings at the lower end, especially when paired with 288/280 or other higher duration camshafts. Certainly the 35-40HP delta from your initial runs was a nice improvement, along with lift in the entire curve. Glad it's running wellOriginally posted by jbfrancis3 View PostSharing dyno results and giving kudos to paulclaude who helped truly wrap up my CSL conversion project.
A brief, recent history of dynoing:
Late 2019 - TTFS dyno&tune - max was 300 whp on their DynoCom. The injectors was maxed out and we knew there was an issue but unable to diagnosis it.
Feb 2020 - back to TTFS - Frank helped diagnose faulty air temp sensor readings caused by improper grounding on the spare DME grounding pin. We corrected it on the spot and final run was 323whp. The graphs looked good but unfortunately, I never took a photo and Frank couldn't dig it up.
Sept 2020 - I got in touch with Paul and asked for some further optimization. I found a local shop called Loudon County Exotics who has a DynoJet. I completed some baseline runs and sent to Paul for his evaluation. That's image #1 with the Sept 29 timestamp, and 307 whp. Paul pointed to the richer AFRs in the low RPMs and offered attempt to improve.
Oct 2020 - Back to the DynoJet with Paul connected remotely. Image #2 shows starting run for the day (which aligns with the Sept baselines) and ending run 2 hrs later. So, the starting run is with the TTFS tune and the end run is the PCS tune. The end result was better than I expected and I am grateful to Paul for significant gains with tuning alone. He gave his best effort to improve the AFR spikes but a ceiling was hit. AFR's are improved from where it was before the overall drivability is vastly improved. Very impressive, overall, from my standpoint.
The final tune was stitched together with the run #12 (best AFRs, green plot) and run #9 (peak power of 347whp, blue plot image #3)
Well done, Paul! The important thing to know is hardware is the same across all dyno sessions mentioned above.
Well done, Paul! The important thing to know is hardware is the same across all dyno sessions mentioned above.3 Photos
Yes plz, relevant side discussions are perfectly fine, but let’s try to focus primarily on dyno results/graphs/etc. Thanx everyone!Originally posted by digger View Postthere are enough uselss oil threads already, maybe keep the discussion here to dyno results of oils or otherwise....Last edited by stash1; 10-20-2020, 06:45 PM.
It's almost useless to look at a lab report without measuring how effective the oil actually is. An oil could be a perfect viscosity yet doesn't protect a darn thing to protect your engine. They don't even test the TBN. These reports aren't much of a picture of what's going on.
Found the dyno graphs yesterday while cleaning out the glovebox!Originally posted by Syfon View PostI second the above motion!
I'll have to dig out the video, however I had mine an a mainline dyno back in mid-2015 iirc. Was stock except the exhaust. Full system, euro headers (car is euro spec), no cats, section 2 three inch status gruppe x pipe, megan muffler. No tune.
Made ~265whp iirc.
For reference, I also ran the 1/4 mile around the same time; 13.37 @ 169kp/h (105mp/h)
Nice results, thanx for adding to the data base!Originally posted by T-Rex View PostHere's mine this week after installing my TMS Airbox and having Hassan tune it. I am very, very pleased with the results!
334whp, 252whtq on CA91 pisswater- Turner box
- HTE custom dyno tune
- Kassel CSL spec HP DME
- Kassel MAP
- Turner underdrive pullies
- SGT ceramic coated headers
- Euro Sec1
- Stock Sec2 / 3
On the face of it, yeah! I kind of expected a slightly bigger delta but perhaps I've found the next restriction.
The general consensus with euro tuners is that US (W)HP = euro BHP, we don't tend to use WHP figures.
So in comparison, a stock euro E46 M3 generally makes 315-330 BHP over here, a healthy car with an airbox and supporting mods generally makes 340-360 BHP etc
Can't wait to see what the restriction is
- Kassel MAP
- Euro Sec1
- Stock Sec2 / 3
I have not, I ran LM when I first got the car, and those samples didn't look as great.Originally posted by enjoy_m3 View Post👍 Out of curiosity, since your oil sample is pretty consistent. have you tried amsoil?
