Originally posted by paulclaude
S54 Dyno Database
Whats the muffler setup and what diameter choke did you go with on the merge to 3.5"?Originally posted by GregS86 View PostEPIC Alpha N tune
SuperSprint Stepped headers
3.5" custom exhaust
4" custom intake with ITG filter
Tilton clutch/flywheel
Underdrive pullies
327WHP, 260WTRQ(#'s are SAE corrected), however this motor will end up detuned for classing purposes.
My Z4 M coupe has been running Epic software from day 1 but I only recently managed to find time for a custom tune. I never did a stock baseline but I know a healthy Z4 M generally dynos around ~275whp (SAE) on a Dynojet. But for purposes of this exercise, I’ll use my header tune as my baseline, which means total pickup of +40whp from airbox, x-pipe, pulleys, and flywheel. Note dyno runs were performed at same facility with ambient temps being quite similar (spring 2024 vs fall 2025).
Lastly, I recognize a more controlled framework would've entailed starting with a baseline header + custom tune but frankly, I wasn't going to pay up for an academic exercise. Ultimately, this answered the most burning questions for me while still having good relative comparison points.
Header Tune (OTS)- Euro headers
- 100 cell hfc
- Peak 298whp / 237lb-ft
Alpha N (OTS)
Same as above plus following additions:- TMS CSL v2
- TMS pulley
- Supersprint X-pipe
- TTV Racing flywheel
- Peak 318whp / 241lb-ft
Alpha N (Custom)- No change to above other than tuning
- Note there were quite few runs and iterations of the tune but this was the "final" version
- Peak 337whp / 256lb-ft
- Likes 7
143k S54
Mods are:
- Epic Alpha N Tune
-Evolve Airbox
-Megan Headers
-Stock Section 1
- Bimmerworld Street Track 3.5"
Stock pulleys, tropical E36 M3 Clutch Fan
The car is wanting to pull timing after 7k rpm, Randy was saying the IATs were pretty high. I did see the logs, and they were about 105-110 degrees on a 85 day. We pulled the headlight out and put a blower pointed at the airbox and were able to get some better numbers. So my next project will be ducting to that airbox.
He also suspects my exhaust is another restriction right now specifically the headers, but it's making enough power for me as of now.Build Thread:
- Likes 4
Dyno’d my E46 M3 car has sub 50k miles
mod list:
OEM CSL AIRBOX
OEM CSL CAMS
OEM CSL EXHUAST VALVES
OEM CSL HEADERS
SUNBEAM 100 CELL
OEM CSL SECTION 2
DIXIS BACKBOX
OEM CSL SOFTWARE
car made 326whp and 242 torque. Contemplating getting a tune done to sneak in some more power if anyone has any suggestions on who to go with would be appreciated. I thought the numbers were pretty close based off me going after the oem CSL ratings.
