S54 Dyno Database
  • Cronenberged
    Anyone know of Sec 3 exhausts that rob power and which ones don’t.
  • nextelbuddy
    Went to the dyno few weeks ago to get a baseline before catless euro headers setup gets installed.
    This is in my s54 M3 wagon.
    Engine was completely torn apart on the engine stand for a fresh rebuild. Piston tops were cleaned, I even soaked and cleaned both camshafts rockers. Everything to get them that can brand new which was nice.
    - ACL rod bearings
    - new genuine BMW head gasket
    - all new intake and exhaust valve stem seals
    - all new gaskets and seals top to bottom
    - complete Vanos refresh with beisan parts and all new lower timing chain guides, oil chain guides, o rings etc.
    - valve adjustment
    Mods are just
    - Geoff steel V1 CSL air box with genuine snorkel and flap
    - CSL stock tune
    - SMG CSL tune
    - stock US catted manifolds, stock section 1, 2 and CSL section 3
    Final numbers were
    301 whp
    234 tq
    Hoping for more with catless headers and an HTE tune
    Click image for larger version  Name:	PXL_20241126_175456294~2.jpg Views:	8 Size:	274.3 KB ID:	286345 Click image for larger version  Name:	PXL_20241126_175456294~2.jpg Views:	6 Size:	274.3 KB ID:	286344 Click image for larger version  Name:	PXL_20241126_165327122.jpg Views:	8 Size:	167.5 KB ID:	286343
  • BMWfanz
    Originally posted by Deen HK View Post
    I’ll contact Hassan tomorrow and see what he thinks. Dyno is booked for a bit so it may be a while before I can get it back on. Definitely something I’d like to get sorted
    Tuner will don't care about actual numbers, cause all dyno will measure different power torque due to settings. All about they care is delta- before/after tune. If you have some doubts- check it on the road, maybe 100-200 (10-130MPH) dragy will sort it out.
  • x Spades x
    282 whp/215 tq on a mustang dyno
    149k miles on the motor
    -turner CSL box
    ​​​​​​-SG catless headers
    -SG catted section 1
    -SG unresonated section 2
    -SG SCZA muffler
    -JB racing clutch and lightweight flywheel
    -HTE tune
    What does everyone think? Had to dump a lot of fuel into it as we were running super lean at first. Hassan was able to restore drivability, thing is a riot around the streets now.
    I would expect 325 with those mods. My old motor put me at 300whp with just the airbox and Alpa N tune... everything else stock.
    I'm guessing it's the dyno
  • digger
    It is unlikely Hassan's tune. if it was me id do a run on a Dynojet to look at the power curve as that is a pretty good benchmark just in case it is simply the dyno. If you look at post 481 that mustang shows much higher numbers but that could be "Dynojet mode" or some such nonsense to inflate numbers but the shape of the torque curve at least looks more normal
  • Deen HK
    Don't believe anyone that tells you there is a setting for a non DJ dyno to read what a DJ does lol they are just guessing/fudging. If you want to know what it makes on a dynojet run it on a dynojet.
    Forget about looking at the peak power number, yours is making basically as low as 200 torque in the midrange at 6000rpm and the curve looks wrong.
  • Str8Six
    I was hoping to make at least 300. The dyno owner had a setting on the graph he showed me that adjusted the calculation and said “on a dynojet we’d make 320, but at the end of the day we didn’t really make 320.” Hassan said the mustang dyno is just a heartbreaker.
    This was my first experience with tuning, so I didn’t know what to expect or how the process works in depth. The car started off super lean with AFR’s >16 through out the entire pull. We added a good bit of fuel and made 292. It was getting hot in the dyno cell and the car did heat soak a good bit.
    can you ask the owner of the mustang dyno if they have a dyno chart of a stock m3?
  • digger
  • WOLFN8TR
    I've been doing a ton of research comparing different header setups and Dyno info. The Dynojet numbers are always higher than the Mustang Dyno numbers for sure.
  • Deen HK
    Originally posted by Str8Six View Post
    it must be the dyno. i would expect those mods to make closer to 320.
    the torque curve looks a bit odd, it peaks at 4200rpm and from ~4200rpm to ~6600rpm it is a slight sag/dipped shape instead of the more usual humped shape. If you look at the mustang one at top of page you can see.
    The numbers are very low
  • digger
    -turner CSL box
    -SG SCZA muffler
    -HTE tune
  • Str8Six
    -turner CSL box
    -SG SCZA muffler
    -HTE tune
  • Deen HK
    -turner CSL box
    -SG SCZA muffler
    -HTE tune
  • Advorsor
    Originally posted by fourmula1 View Post
    More out of curiosity than anything, isn't this setup capable of much more? Is the limiting factor the tune? Or exhaust too restricting? Is this capable of 350+?
    Its probably the exhaust setup.. Its very Frankenstein-like. I'm also pretty sure I have an exhaust leak somewhere.
  • fourmula1
    Originally posted by Advorsor View Post
    336whp / 255lb-ft on my ~80K mile engine.
    Mods:
    - CSL Airbox (Haimus)
    - 280/272 Cat Cams
    - Euro/CSL Style Headers
    - Dinan High Flow TBs
    - Eisenmann Muffler
    - TMS Pullies
    - Mishimoto Electric Fan
    - RK Tunes / Alpha-N
    - 93 Octane (various)
