I haven't read Bimmerfan08s DIY but all in all its not a crazy difficult job. The torque sequence is a massive pain in the ass though, especially for later year cars where its 105 degrees instead of 70. And keep the oil pan center cover off the oil pan when reinstalling or you'll never get it on. Completely dropping the front subframe will also make this job so much easier. If you dont drop the whole subframe, and opt to just let it hang, remove the FCAB bolts on both sides so you can swing the subframe front to back when you need to. Just take your time, and take the torque sequence very seriously.
Rod bearings
Originally posted by chicane View Post
Can't access it.Topaz e46 m3- karbonius csl airbox and snorkel w map, turner power pulleys, csl headers, euro section 1, ss x pipe, scza exhaust, besian vanos, jrz rs1, turner sways, akg and Rouge bushings, Rouge front strut bar, turner adjustable camber arms, cmp Stage 1, 2, & 2.5, custom red and mdash interior, cobra nogaros, brey kraus harness mounts, bsw speakers, autosolutions 30% ssk, advan rs2s (street) and apex arc 8s (track).
e30 s62 swap (current project)
i like the sound of this. The engine on my car was replaced and when i asked the seller what year was the engine from he was not sure, as it was the owner before him. Will it just make sense to replace the connecting rod bolts? or is there another way to find out what year the engine is from, for torquing purposes mainly?
Originally posted by trudriv3r View Posti like the sound of this. The engine on my car was replaced and when i asked the seller what year was the engine from he was not sure, as it was the owner before him. Will it just make sense to replace the connecting rod bolts? or is there another way to find out what year the engine is from, for torquing purposes mainly?
Also, you use different bolts depending on the years (which correspond to different torques, see post # 25). If you cannot find a date, you could always worst case just buy the bolts for either scenario and return them if you reuse.
I would recommend reading through the entire DIY prior to buying parts or attempting obviously.Topaz e46 m3- karbonius csl airbox and snorkel w map, turner power pulleys, csl headers, euro section 1, ss x pipe, scza exhaust, besian vanos, jrz rs1, turner sways, akg and Rouge bushings, Rouge front strut bar, turner adjustable camber arms, cmp Stage 1, 2, & 2.5, custom red and mdash interior, cobra nogaros, brey kraus harness mounts, bsw speakers, autosolutions 30% ssk, advan rs2s (street) and apex arc 8s (track).
Originally posted by lunardds View PostWhere are you ordering your Acl from? Prices are all over the place
https://store.langracing.com/acl-rod...mw-e46-m3-s54/2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by sumolbandit View Post
I think the engine vin is under the headers. The head should also have a date stamp but i am not sure where.
I will check this out before hand. Not a daily so its okay to wait for the bolts if needed. thanks!
ACL Race Rod Bearings Standard Size For BMW S54B32 (3.2L) M3 E46
1 Photo
Originally posted by DESMDR3 View Post
I just ordered off Amazon. They are the standard ones 6B1569H-STD. Seem legit, ordered from 4wheelonline and it got dropshipped by Turn 14 distribution
$112 https://throtl.com/products/acl-race...acl6b1569h-std
$100 https://www.maperformance.com/produc...e-rod-bearings2002 M3 | 1986 R80 | 2001 EuroVan
Cheaper just to do these every valve adjustment instead of Blackstone analysis. Wow. I paid close to $500 for WPC ones when I was doing mine.
Youtube DIYs and more
Budget CSL MAP Conversion
Well I'll justify my extra $60 spent on supporting a good business. That is a steal for those bearings.This is my Unbuild Journal and why we need an oil thread
- Likes 3
I spent some time the weekend and this morning comparing FCP Euro's kit vs Bimmerfan08's (Zach's) list from his DIY instructions.
FCP included an Oil Pan Center Cover (11137834885). This wasn't in Zach's and seems to be a bit of overkill, I don't see this needing to be replaced and seems like an easy $65 in revenue for FCP for those who don't look into it - thoughts?
Zach included power steering hose gasket rings - these are not included in FCP's kit, and the part numbers he provided show they are only compatible with e36 M3's, not e46. Do these need to be replaced or can we reuse what we have? If we need new, does someone have the part numbers by chance?
Zach included 4 front control arm bracket hex bolts, FCP did not. Consensus on replacing these? They are relatively cheap ($10.64) so not a huge deal.
Some other thoughts:
My M3 is sitting at 103.6k at the moment. Prior owner didn't seem to drive the car hard which I am appreciative of. I am also thinking of the "while I am in there, may as well replace" and this is the list that I have come up with as a maximum to do. Is there anything on here that would be considered overkill or unnecessary?
-Motor mounts and flange nuts (must, I have seen them while fetching a dropped crush washer during VANOS and they need to be done)
-Steering shaft coupler
-Control arms and tie rods (I have been going back and forth on this, these can add $$ to the job quickly, but at 100k its about time for a refresh, will pushing these off create a ton more work for me in the future?)
-Oil level sensor (based on comments above, don't need to fix this unless its failing. Easy replacement during routine oil change)
-All pulleys and belts, as I have no record of them being done. I have a small squeak when cold starting but quickly goes away, probably a pulley.
-Sway bar bushings
-Fan clutch (is there anyway to tell how much life is left? Living in the Midwest, I don't often see myself sitting in traffic in high ambient heat days anyways so I could remove it all together)
-Power steering components. I haven't decided on what what be done, can do more research if it is recommended.
I'm also leaning towards ACL Rod bearings from either Lang or MAPerformance. MAPerofrmance has a better deal at the moment, which is about $100 for a set. At that price I could replace my bearings 5x before breaking even with OEM at FCP.
Originally posted by Inizes View PostI spent some time the weekend and this morning comparing FCP Euro's kit vs Bimmerfan08's (Zach's) list from his DIY instructions.
-Sway bar bushings
I'm also leaning towards ACL Rod bearings from either Lang or MAPerformance. MAPerofrmance has a better deal at the moment, which is about $100 for a set. At that price I could replace my bearings 5x before breaking even with OEM at FCP.Last edited by COVID-19; 05-04-2020, 07:07 AM.06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
