I wanted to update this post with my two new additions to the Match amp upgrade. The new Sony 6000 double din head unit and my Audison Prima 10” powered subwoofer. (yes i know the wires are ugly) lol Have something coming to cover that for the clean look. Also I would like to report I have had no issues with the Sony after the latest firmware. Now on to the subwoofer. This little subwoofer is amazing!, the sound is finally good in the M3. Hopefully this helps someone with their decision.
My new amplifier upgrade
Someone could reach out to Techniq and see if they would do something custom. It wasn't that long ago they were selling E46 harnesses. I got one within the last 2-3 years. Attaching some files here that might be useful. Whatever you do, make sure to ground your amp with everything else in the driver's side trunk area near the backseat. Grounding to the battery is no beuno.
- Likes 3
Originally posted by Phoenix///M3 View PostSomeone could reach out to Techniq and see if they would do something custom. It wasn't that long ago they were selling E46 harnesses. I got one within the last 2-3 years. Attaching some files here that might be useful. Whatever you do, make sure to ground your amp with everything else in the driver's side trunk area near the backseat. Grounding to the battery is no beuno.
Originally posted by PowerSax View Post...but is the wiring plug and play? or does this make it so?
Originally posted by t3ddftw View PostIf you have HK, you could still run this amp if you're willing to replace all the speakers at the same time, with say, the BavSounds speakers for non-HK cars.
Originally posted by Shonky View PostWhy would you do this? You're replacing the amp with something with a DSP and full eq across all the channels. Just tune the amp properly.
From what I remember the hk were a mix of 2,3 and 4 ohm and the non are 8 ohm. If this is true, been a while, then then the Audiotec Fischer should be better suited to the HK being a 4 ohm amp..
I have a pp82dsp 8 channel amp out of a f10 5 series with hifi and it appears to share a harness with the e46. I don't have my car with me but bought a hk amp pigtail to trace it out sofar it seems like it should work, not pnp. Bad pics attached for reference.
As far as I am aware, the HK / non-HK have different speaker impedance's but maybe I'm missing something!
Originally posted by Shonky View PostMaybe so (and yes I think that is correct). But what difference does it make if the replacement amp can drive the impedance and is fully tuneable?
Drivers with different resistance are chosen as a way of tuning I believe. And none of us are going to tune better than Harmon/jbl employees.
Perhaps one driver might have lower resistance, but has lower sensitivity so it's output could be same as a driver with greater resistance, but also greater sensitivity. I'm not 100% sure, I never got that deep into car stereo.
Personally, stick with OE setup or go full custom imo.Last edited by Tbonem3; 12-30-2022, 01:42 PM.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
