What a horrendous thread. If its gonna sink why not sink it to the bottom.
The ethanol, which is alcohol, has two downsides in our applications: 1) attracting water and 2) causing elastomers to swell to a varying degree depending on the which of the many formulations is in use.
Ethanol does not cause clogging of carburetors: the gumming or varnishing as its often described as is due to olefines in modern fuel blends. Separately, the aromates also have a negative effect on elastomers. Those two items have positive attributes as well, mind you.
Everyone is pulling ethanol out of complex formulation and saying that it making or breaking the case. Some of the modern formulation is attributable to addition of ethanol but many aspects are not.
