I know that the common approach is to tap into the wire in the homelink but is there a way to route the wires into the fusebox/glovebox? I want to use that method for connecting both parking and while driving.
Dashcam wiring into Fusebox
Yes. See my edit in a few mins.
When you remove the A pillar cover, you’ll see some wire retaining clips. I used those to make sure the dashcam wires didn’t get in the way of the airbag. For the ground wire, I used one of the bolts for the pass front airbag mount.
https://nam3forum.com/forums/forum/m...316#post168316Last edited by SQ13; 02-06-2023, 01:31 PM.
Can also go all the way to underneath the center console and use the eject box wiring (factory option for a phone). Has switched and constant 12V:
Factory Specs Production date: 2002-04-16 Type Code: BL93 Body Type: Coupe Transmission: 6MT Exterior Color: Topasblau (364) Interior: Powered, lumbar, non-heated, black nappa (N5SW) Options: Sunroof, HK, CD53 Misc: MK20, MSS54, M11 rod bolts Maintenance Engine Oil: 124,077 mi (Feb 06, 2021) Coolant: 123,200 mi2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
This is exactly the approach I'd like to go for.Originally posted by SQ13 View PostYes. See my edit in a few mins.
Did you have to pop off the front of the headliner to route the wire to the A pillar?
Which fuses did you end up piggy backing on?
thanksLast edited by 4getr34; 02-06-2023, 05:37 PM.
Can’t remember. I may have had to lower the front right just a bit to tuck the wires properly and ensure they don’t pop out. Removing the passenger sun visor should be sufficient.Originally posted by 4getr34 View Post
thanks
I’ll have to follow up with you on Thurs for the specific fuses. I’m away from my blue car, which has working parking mode.
Also, a fan of the phone loom for switched 12v, easy to get to.2004 Silbergrau Metallic 6MT
No constant 12V up there though, so still would need to run that wire.Originally posted by Rekpoint View PostWhy don't you wire it into the Home Link plug in your headliner? You can buy the pins and connector online and make it 100% reversible by making a harness.
These are the PNs you will need
2x BMW-61130005198
1x BMW-611369319292002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
