DIY alignment
    DIY alignment
    There was a diy alignment thread shared (could have even been from the old forums) that I can't find via search. Does anyone have access to it?
    I am trying to calculate the correct distance from hub to string for front and rear accounting for track width difference.
    TIA
    The front track is 59.4 in/1508.76 mm and rear is 60 in/1524 mm. There are diagrams on google and other resources. So the string should be about 8 mm further from the front wheels on each side. This is assuming stock wheels.
      You thinking of this one?
      Earlier this year I had it in mind to write up & share my matured process for aligning the E46 M3 chassis. I've been 12 years now developing the tools & techniques for doing a really accurate job, on the M3, the 330Ci I had beforehand and my 911. I've saved a stack of £££ by going DIY, it works v well, for toe, just
      Build Thread:
        Or this one maybe?
        I wanted to share the my alignment spreadsheet with this community. It's applicable to anyone doing a string alignment at home, with whatever tools and methods you're using. I previously shared a link to a similar version in someone else's thread, but I have progressed this file a bit since then. Google docs to my setup
        Build Thread:
          Thanks for sharing these. Although these are great, they're not the thread I'm thinking of. I don't remember enough detail to describe it.
            You just need to get the left and right the same. I don't think there is a correct distance. All you are trying to do is make a box around the car.
