Show me your M3 badge placement on your CSL trunk lid
    Picking my car up today with new CSL trunk lid & still haven’t finalized M3 badge placement.
    '01 M3, JB/IR, SS, TCK DA, Apex, TMS CSL, HTE, 4:10 gears - original owner
    '00 slicktop Touring converting to full M3 Touring
    Somewhere (I'll try to find it) there is a post that shows where it goes.
      Hi all, I'm 90% done with my CSL trunk install, so I thought I'd write up a DIY with some installation tips. Since they became available again, the CSL trunk is a popular mod on E46 M3s. However, the information out there currently is somewhat vague on what you actually need. Hopefully this clears things up. Sourcing a CSL
      The badge placement needs to be adjusted slightly without the "CSL" portion.
      You might want to wait a few weeks before installing the badge to let the paint fully cure; otherwise, the badge can create an indent in the clearcoat and you'll see it if you remove it in the future.
        Looks like 41mm from right edge and 15mm up - thx for sharing
          I stuck mine on the same center line as the CSL. Looks weird to me if it's shifted all the way to the right portion of the CSL badge.
          Only pic I have on hand on my work computer:
          Click image for larger version  Name:	IMG_0458.jpg Views:	0 Size:	130.5 KB ID:	213773
              Pictures from the photoshoot used to be the desktop background on the family computer when I was in high school 🤣
              📸 @alpinem3
                Here’s mine I eyeballed…
ID:	213799 Here’s what I ended up going with. RE:fresh paint, car was baked twice and it’s also probably 2 weeks old now before we applied the M3 decal
ID:	213804 Mine is a little lower than some of the others on here. Definitely make it even/level with the ridge that goes across the trunk
                      Perfect 👌
                        Low rida
                          Click image for larger version  Name:	IMG_1931.jpg Views:	0 Size:	177.7 KB ID:	213945
                          Used gloss black F80 M3 emblem - M3 badge position is halfway between "stock" and CSL
                            Here is where I put mine:
                            Click image for larger version  Name:	image_37967.jpg Views:	470 Size:	102.6 KB ID:	183095
                            Click image for larger version Name:	IMG_20220605_164031_Bokeh.jpg Views:	25 Size:	102.0 KB ID:	183096
                            Click image for larger version Name:	IMG_20220605_160348.jpg Views:	25 Size:	153.5 KB ID:	183098​
                            I explained why in this post:
                            https://nam3forum.com/forums/forum/m...077#post183077
                            EDIT: I didn't realize you had done this, but this is why I positioned mine where I did too:
                              A friend of mine has no M3 badge on his CSL trunk, and it actually looks pretty great.
