Hey Fellas,
So ive installed the repkacent engine into the car. Ive also rplaced the clutch and fork spring... then put evefything back together.
Double cklhecked all lines and tried starting the car... Nothing... just clicks. Repkaced the battery and same thing.
Ran SMG tests in INPA and it passes the Actuator bleed... but it akways fails the clutch bleed (test 2). The error is (Slave Cylinder/Hard lines). So i replacent both Slave cylinder and all smg hard lines and still the same error.
Does anyone have any other suggestions?
Much appreciated!
Kareem
Much appreciated!
Kareem
