FCAB - what’s best?
    FCAB - what’s best?
    I’m planning on my list of items for a front end refresh to go along with rod bearings this fall. One of those items are the FCABs. I was planning on doing OEM or the OE equivalent, however I know there are some other options out there. Is there a particular material that responds better without making the ride harsh for street driving? My car is mostly a weekend warrior and garage queen. So far, I have been restoring/building it to OEM+.
    Build Thread
    I use the Turner delrin monoballs in my HPDE car and they're fantastic. I have Rogue's street poly offering in my daily. This is the only bushing position in which I prefer poly on a street car.
      Turner Monoballs or if too much I would do OEM. Seen a bunch of premature failures on most poly.
      Budget CSL MAP Conversion
        Oe or lemforder rubber for street car. Solid kills the steering for me. Poly will shake/vibrate you to death. You'll feel everything, good and bad. With rubber, the bad is isolated and you just get that beautifully sweet bmw steering.
        There are many good mods to do for better grip and behavior up front imo.
          Anyone use the rein branded ones?
            Can anyone chime in the NVH on the turner monoball? They claim there isn't but I'm not so sure
              Rein is the R in CRP (Continental-Rein-Pentosin), so not a cheap knockoff brand per se. Some of their stuff I've bought has been totally fine and clearly equivalent to OEM. But I've also heard of some parts being low quality. I don't know where the FCABs would fall
                Now i'm with BW TrackCAB and works great.
                  I used Powerflex purple for my flcab replacement.
                  They are as comfortable as OE.
                  I have had a set for ten years on an E30 chassis and they are still tight.
                  A Longevity issue for poly/OE flcabs is the heat coming off those cars with the cats up in the primaries.
                  The right side flcab gets baked by the exhaust and the factory cup headshield is insufficient. I think 50k miles is all one can expect from the rs flcab with the factory heat shield.
                  I would not use poly to replace OE bushing material on any other chassis/suspension area of a street daily. The NVH is tiresome when punting around town. I made this mistake with AKG poly for the diff mounts in my E36 M3.
                    I have Turner Motorsport Poly 80A - which are a softer version of the 95A - they're supposed to be somewhere in the middle between a solid and stock bushing. They use a delrin sleeve to mate to the control arm. I've only driven 6 miles on them, but I can't say I noticed any noise/vibration. So far, so good.
                    Japanrot Red E46 330i Msport k24/dct/turbo Build Thread
                      Another vote for OE/Lemford.
                      T​​​​he part is easy to replace and cheap enough that I would prefer replacing them with OE parts as they wear.
                      Had poly installed for a short time and I wish I had known!
                        Been running Oe Lemforder for several years now, good quality, very comfortable, before ran AKG poly 95a which failed prematurely would not recommed poly fcab, recently pulled trigger on Turner Monoballs after hearing good things about them, haven't installed them as yet though, will report back with results how they feel.
                          Oe lemforder for me. I tried rouges poly and the front right melted after a year.
                            Think I’m leaning Lemforder at the moment. Will continue to monitor what feedback comes through
                            Build Thread
                              I recently had Poly FCABs fail prematurely, likely exacerbated by crappy Michigan roads, and replaced with OE. I forget how Columbus roads are but if there are rough areas, OE is probably your best bet for a street car. Much more forgiving without any large noticeable detriment.
                              -Brandon
                              2005 M3 BMW Individual Sterling Gray / Imola Red 6MT
