FCAB - what’s best?
    Originally posted by Seagull View Post
    Wow! those are both quite the premium over OEM. dont think I would have splurged either way.
    Perhaps, but every RTAB replacement necessitates and alignment, and these should last 2-3x longer than stock. Probably cheaper/mile if you're keeping your car a while.
    Plus they significantly improve rear end precision.
      x2
      2002 M3 Carbon Schwarz/Black 6MT
        I have had the cheap MTC poly bushings fail after 1 week on my 330Ci, replaced with Powerflex poly and have had no problems. On my M3 I have Rouge Engineering poly and have no problems.
        Pic of failed cheap MTC poly bushings
        2004 M3-Silver Grey Metallic/Imola Red-Coupe-6spd
        2002 330Ci-Topaz Blue Metallic/Black-5spd
        Instagram- Norocehcap
          Many, MANY people have had the powerflex FCABs fail.
            Assuming the FCABs in your car are original, new OEM Lemforders from FCPEuro will be a huge improvement over 100k mile rubber pieces. Unless you're tracking the car, I think your money will go further in other mods to improve steering feel (if that's something you're even concerned about).
              In case it helps anyone, I pre-press OE rubber into good used housings for folks. Been doing this for many years and had a thread like a dozen pages long until M3Forum died.
              pair of new OE FCABs (front control arm bushings) already pressed in (used lollipops). For all e46 m3s. Ready to slip on to your control arms and bolt on for revitalized handling. No messing around with DIY or machine shop pressing out/in the bushings. New pair of OE bushings already pressed in are about $135. Selling
                https://nam3forum.com/forums/forum/c...-pressed-in-89
                +1 for the_fly. Bought his prepressed Turner monoballs. we Had to work through Turner QC issues and he's handled it very well.
                Even though I ended up with factory rubber, it was not the_fly's fault. The Turner monoballs had too many gremlins to deal with and I got fed up with it.
                  Oe or lemforder rubber for street car. Solid kills the steering for me. Poly will shake/vibrate you to death. You'll feel everything, good and bad. With rubber, the bad is isolated and you just get that beautifully sweet bmw steering.
                  There are many good mods to do for better grip and behavior up front imo.
                  Like what?
                    Originally posted by S14 View Post
                    Like what?
                    Proper alignment.
                    Better tires.
                    Better dampers.
                    Refreshed LCA.
                    Refreshed Tie rods.
                    In that order.
                      More neg camber (alignment was said ^)
                      Wheel width changes
                      Steering rack - zhp/zcp/csl
                      Swaybar and/or "setting" choice
                      Strut bar, if older model
                      Less weight, esp strategically removed (location wise)
                        not a huge fan of the powerflex FCABs. I installed a set, hit the track and they blew on my second session, completely melted and extruded themselves from the end of the lolipop. Went back to OE and its held up
                          I said it in other FCAB thread here recently, look into Whiteline FCABs if you're leaning OE. Would not go back to poly. Curious about monoball but so far it seems the reviews are mixed.
                            I have a turbo next to my passenger fcab and the poly ones don't last long at all. The Turner monoballs have been great so far.
                              Proper alignment. ✔
                              Better tires. ✔
                              Better dampers. ✔
                              Refreshed LCA.
                              Refreshed Tie rods. ✔
                              In that order.
                              More neg camber (alignment was said ^) ✔
                              Wheel width changes ✔
                              Strut bar, if older model ✔
                              Cool thanks guys, looks like I'm on the right track so far.
                              What strategic weight loss are you referring too?
                                I have a pair of rogue poly FCABs sitting in a box, I am undecided if I will run those or stick with OE. Who has run these and can provide any feedback on the street variant?
                                Current:
