Originally posted by BMWahba
Misfire - Wet Spark Plug on Cylinder 3, But Cylinder 4 Low Compression...
Originally posted by sapote View Post“It sat with "oldish" fuel in it, that was the worse thing that happened. And that fuel was about 6 months old, max.”
A year old fuel is nothing to worry about.
Update:
spoon full of oil got compression on cylinder 4 back up to 150.
so please, can someone help me understand what is going on. This is so strange.
Again for clarity: Cylinder 3 is the one that I would suspect a “wash out” considering it was visibly wet. But cylinder 4 is the one I had a low compression on. After adding oil, on a cold compression, all cylinders are reading 150.
How can I rule out a piston ring issue at this stage?
for safety, I am swapping all 6 injectors with a used spare set.
Originally posted by BMWahba View Post
Hence my extreme frustration, sadness and confusion all at the same time. This car was running perfectly and I don't beat on it. It sat with "oldish" fuel in it, that was the worse thing that happened. And that fuel was about 6 months old, max.
I tested it twice cold, one at 98 and the other at 102.
I am doing the oil spoon method today. Will update.
You snag a borescope?
Do a leak down and see where all that “lost” compression is going.
on my engine that had a blown HG it was very easy to feel/hear the air moving into adjacent cylinders and out through the block with my worn rings. Cylinder walls looked perfect, however.
Yea definitely makes not much sense. I am going to swap plugs today, put it all back together and idle it. Then do a warm compression. The boroscope is how I got those picture of the pistons but I wasn’t able to look in the walls. The camera didn’t really fit to turn it towards the walls or it was too shiny.
My guess is some o-ring, probably on an injector, is letting fuel wash out Cyl4 when it sits. But that's a guess from WAY far away. I wouldn't suspect a coil or plugs or rings or the cylinder itself.
Seems like a "when it sits" condition only.
mawLast edited by maw1124; 06-20-2023, 06:02 PM.
Yes. I will be sending my injectors out and in the meantime, I put in a spare set which were verified good. I should see the results of the injectors when they get them to rebuild/test to see if they were faulty.
For now, I’ll get the car put together and drive it a bit to see how things do.Last edited by BMWahba; 06-20-2023, 10:43 PM.
