Originally posted by jet_dogg
Misfire - Wet Spark Plug on Cylinder 3, But Cylinder 4 Low Compression...
Not sure what I’d be accomplishing. My cylinder 3 was wet but that was not the low compression cylinder. Logic would have it that cylinder 4 was the one that’d be wet with low compression from a wash out. But again, no clue.
I came here to say this but jet_dogg beat me to it.Originally posted by jet_dogg View PostWhy don't you swap the injector with one from another cylinder?
In a situation like this swapping in a "known good" part isn't something I would personally do unless it was literally right now in a running car. Say your injector has been sitting on the shelf for 6 months and something has happened to it. You put it in cylinder 3 and nothing changes... because it is also bad now your diagnostics are thrown off.
Instead swap injectors between cylinders and see what happens. IF you confirm the wet cylinder (or misfire) followers the injector THEN put the "known good" injector in it and see if the issue is resolved.
Cyl 4 & 3 are companion cylinders, sometimes something that happens to one affects both.Last edited by George Hill; 06-21-2023, 06:36 AM.'09 HP2S, '12 R12GSA, '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Alpine 330iT
Email to [email protected]
I understand. Noted. I am sending my set of injectors out to get cleaned anyhow.Originally posted by George Hill View Post
An update on my Injector testing... here were the results. Any thoughts on how this corroborates with the symptoms in this thread? Cylinder 1 and 3 were dripping, the rest were in "fair" condition. Cylinder 4 was the one that had low compression...still kinda doesn't add up.
Does anyone know if the ECU averages out the fuel injection across all 6 cylinders or is it read per cylinder?
Drive it hard, avoid short trips and turning it off after low rpm driving/not reaching full oil temp IMO.
Recipe has always worked with my 225k e36 and 183k e46.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Or maybe it's a sign to just let her go!Originally posted by Tbonem3 View PostDrive it hard, avoid short trips and turning it off after low rpm driving/not reaching full oil temp IMO.
I think there is no issue with the car, but just parked long and low batt, which can cause misfire then washed out cylinders led to even bad idling. Don't turn off a cold running engine less than 5 minutes in the run.Originally posted by Bert30 View PostDid you happen to figure out that the issue was?
