Motorsport Thermostat
    Stumbled across the OEM BMW Motorsport thermostat for the S54. Anyone running this thermostat for their street car?
    PN: 11531417215
    Did some research on the part and see that it’s technically not for street use cars… however, it’s not apparent to me why. I’m rounding up parts for a cooling system refresh and considering this as an OEM+ alternative to the standard thermostat.
    Some screenshots from Bimmerworld’s listing:
    📸 @alpinem3
    Does your car currently run hot? If not then this is not going to be beneficial. Cooler isn't automatically better. If your engine runs too cold (e.g. can't warm up and stay warm enough) you're going to increase engine wear.
      Never heard of anyone using it.
      Typically water temps are not an issue. Rather oil tends to be too hot on track, so people use an oil thermostat dummy, which always lets oil through the larger cooling loop. Drops oil temps by ~5°C.
        Stock thermostat is 80c IIRC, a 55c thermostat seems pretty excessive to me.
          55c is a performance mod but you need to modify the engine tune otherwise the engine will never know it’s “warmed up” so to speak so mixtures will not be correct
            A mod like this is for a track only car that gets trailered to the track. No need to OEM+ this part. Stock part just works.
              Yes, definitely not for street driving
                Even if it does run hot, this is not going to be beneficial.
                Thermostats help keep the coolant temperature above a certain temperature, not below.
                2003 Imola Red M3 w/ SMG
                  Of course, I am dumb 🤦‍♂️
                    The engine should run at the thermostat temp when moving at speed else there is a problem or insufficient cooling capacity if upgraded power mods. I’ve used colder thermostats on other cars and the engine will operate cooler except at slow speed in traffic it will likely creep up but come back down when moving again . Obviously it’s not there to fix cooling system or overheating issues
                      For those of you running Anri's 70 or 75 thermostat, does it take longer for the oil to get up to temp?
                      My thermostat decided to get stuck open the other day and I'm not going to rush to replace it if it is going to act like the 70/75 thermostats. Coolant temp reads 70ish at idle, can drop to 66 when cruising on the highway and only maxes out at 75.
                      This Wahler thermostat has about 6 years and about 20k miles on it. Aren't thermostats supposed to last longer than this?​
                        I have Anri’s thermostat in mine (edit: and to clarify, it's a 70C thermostat) - oil temps seem to come up as they did before. Been super pleased with it so far, last summer in 105 degree temps with the A/C on in LA traffic the car was reporting between 78-83 C
                        - Jonathan
                        2004 M3 - Build thread
                          Yes, going from 80C to 55C would be extreme, but running a colder thermostat in-and-of-itself isn't going to damage your engine. There's almost no reason not to run a colder thermostat, especially in California.
                          2004 Dinan S3-R M3
                          2023 X3M Competition
                            Downgrade.
                              Yes it takes longer without a doubt to get up to temp. The advantage I have found with the lower temp thermostat is in decel zones like 10a-10b at road atlanta, you can get get quite a bit of heat out of the motor, since the thermostat closes later.
                              If my car were only a street car it would really not have an advantage. In day to day use I have to consider the longer warm up times, it isn't ideal but is what it is.
                              Build Thread:
