Diving in:
Few things to note the Concept applied from whoever performed the service
for this engine perviously.
I always say their isn't a wrong concept by one choosing what to do, but
their is not an optimum set up!
- The exhaust side hub design is very goofy...the biggest downside
of this design is that the hub is TiG welded!!! TIG welding parts is great
because the heat penetrates very deep resulting the parts to warp
for sure. Delicate area/s like the helical gear may/will be affected, one never
wants to have welded parts which are warped. I mean we are talking very
little just few thou and that is all you need to have wobbly part/s..In areas like
let say suspension, roll cage, 1-2-3-4thou it won't make absolutely any difference..
I am sure they will argue till the cows come back from the grass field which
may be months that its not a problem but in my engine I will prefer to have
the OEM or Beisan hub machined from 1 solid piece
- The oil pump disc remained with oem size holes. The welded drive pins are
lose in the hole which is resulting rattle at around 2000-2200rpm range from
both camshaft back/torque operation.
- Next, one spent all of of that bloody labor and did not replace the 8.8 cam
flange bolts ?
Moving forward.
Regards,
Anri
flange bolts ?
Moving forward.
Regards,
Anri
