THE M3 IS GETTING THE ANRI BUILD TREATMENT - Blown headgasket to build thread
Sapote,Originally posted by sapote View Post
Im confused. Why lapping the spacer would damage the bearings?
First I would say explain what method
are you planing to use ? Lap the
parts individuals separate or ? You have
to describe in deep details I can not be
guessing what method are you going to use...
But let say the std method will be to put
the lapping compound and assemble the
parts and have fun left and right..
The lapping compounds are very
abrasive, the needle bearing must
be glass smooth when it's installed
inside the plastic "cage" during work out.
Why do you want the needle bearing to receive
abrasive surface by lapping it and
compound will be all over the place ?
I told you much better way, take
0.001" each pass by shortening the
cylinder in order to expose the washers
flat with the cylinder.
Cleaner, better and not making the
surface abrasive rough and messy
by using lapping compound that can damage
the plastic cage.
When I was perfecting my valve seat
to valve method, I was trying different lapping
compound. When the media is rough its was
leaving micro lines on the valve seat and the
valve contact ring line. I end up with the softest
lapping compound available so I can just check
my valve job for hi and low areas.
Regards
AnriLast edited by Anri; 02-19-2024, 04:27 PM.
Cranked the engine several times with
fresh oil and spark plugs out to reduce
pressure on top of the bearings, light off.
Primed the injectors and it started from
half a turn like your daily driver before
you go to work in the morning.
Took it for ~50miles Break-In my way with
heavy heavy loads. It runs flawlessly.
Few more miles spark plugs out to test
leak down and assemble the cabin filter
and the rest.
Regards,
Anri
- Likes 6
With the splined shaft removed, clamp down one end and measure the axial plays of the other end with a dial indicator. I.e. if the plays is 0.002" then I lap down the cylinder spacer by the same amount of 0.002" -- a little less is ok but not more than 0.002". Not touching any other components.Originally posted by Anri View PostSapote,
guessing what method are you going to use...​
Fun to follow as a casual driver/racer. Thanks for sharing.
I need to do waterpump, FCP sells the genuine without(?) the impeller. Whats the best route here guys? My understanding from reading this thread is that I want a oem with plastic impeller design. This is for my race car. Where can I find or piece together the assembly that offers lifetime replacement?
Thanks
Okay, in order to take 0.002" with lappingOriginally posted by sapote View Post
compound what you will find is the surface
will be scratched by a lot and you are not
going to like it, Sapote. Then will have fun
polishing the parts to mirror finish as they
from the factory, smooth.
Sapote, "there are thousand ways to skim the cat"
I think you chose # 1000 from the list easy to hard.
I personally will machine the cylinder 0.002" and keep the
plastic cage and the shims factory untouched, but again that
is just me.
Regards,
AnriLast edited by Anri; 02-19-2024, 04:56 PM.
Anri,Originally posted by Anri View Post
Sapote, the saying says "there are thousand ways to skim the cat"
I think you chose # 1000 from list easy to hard.
is just me.
Regards,
Anri
I don’t think my method is different than yours, except I lap the cylinder spacer (don’t have a lathe) and you machine it.
No need to polish the spacer as it doesn’t serve as a bearing surface.
Gents,
After the engine refresh I connected the battery back in
and the trip odometer resets to 0. I noted earlier today
that I drove the engine exact 40miles including going to
the shop today to check the leak down and assemble
everything.
Results are:
Cyl #1-2-3-4-5-6 do have exact ~3% leak down <1%
This is only for 40miles, that is pretty gooooooood.
Give the engine another 1000miles and it will improve
with another 1%. I like to check the leak down under
100miles after rebuild to monitor how fast I was able to
sit the rings, valves. Usually on a fresh motor sitting on
the engine stand leak down varies in-between 7%-10%
and all is thru the rings.
Spark plugs are all even color.
Car is ready to cover 200k miles if maintain properly
and of course without overheat and regular 10W60 oil
with moly and zddp additive, no problem.
This project is now completed. Going back to the other
S54 engine ready to hop into E30M3 and 2) S62s one
in E24 and the other into Imola Red E39M5.
Regards,
Anri
- Likes 9
Lovely work and a great thread to read Anri, thank you.Originally posted by Anri View PostGents,
and of course without overheat and regular 10W60 oil with moly and zddp additive, no problem.
Which engine oil do you use in S54 engines?
I have been told in the past that the OEM Castrol 20W60 doesn't cling to the components in the top of the engine.
Is 10W40 not a better option, at least on a rebuilt low mileage engine?Last edited by ac427; 02-21-2024, 01:59 PM.
Hi Feff,Originally posted by Feffman View PostAnri, have you ever lightened/knife edged/balanced a crankshaft for an S54 rebuild? If so, any thoughts?
Feff
Thanks for the question.
This is well off subject, this question falls into
race engine build.
Never ever ever knife edge any crankshaft !!!
It will destroy your main bearings. I have tested
this 16 years ago.
Why ? the function of the Fillet is to counter the weight
of the rod+piston combination.
I went very deep into Crankshaft study and design because
I am in a process of making some stroker cranks.
From many specific areas around the crank this area is
called "Balance Factor" I started to reverse engineer
the BMW crank by study what balance factor they are
using. I don't want to go in deep because this post will
be like prescription drug from the hospital...
BMW did lighten the S54 in extremely clever way,
look at the counter weights but they keep the balance
factor perfect and why on S54 main bearings last 200k+
Pic bellow is from a crank I cut to study what balance
factory BMW Motorsport used in their crankshaft.
Benefits ? When I did lighten that test crank I was able
to remove 9lb that is pretty good chunk. My revving characteristics
barely I mean barely got improved if ANY and that is because the
crankshaft as radius is so low as opposite of Flywheel or let say a
piston. It did improve my Windage in the oil pan by 0.0000000001%
S54 crankshaft is already light, if remove may be 2lb will
do nothing to you I mean nothing but problems with the main
bearings.
Regards,
Anri
Definitely. All the best with it.Originally posted by ChapterM3 View PostCANNOT WAIT to get the car back 😃 Those leak down numbers are looking gooooood!! 10w60 is only what I've used and what I'll continue to use going forward
I've been running Motul 300v 10w40 Ester based oil. This was recommended by the guy that built my engine. He is the same guy that builds the engines for Evolve.
So i was just wondering what Anri thought about different grades of engine oil in general.
Personally, I'd reverse the question and ask why your engine builder recommends an oil viscosity not specified by the BMW engineers.Originally posted by ac427 View Post
So i was just wondering what Anri thought about different grades of engine oil in general.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
- Likes 4
