r4dr Is it possible to make larger rotors, like 355 mm and have them work with 996 calipers? Y’all sell larger rotors with caliper spacers for a bunch of Porsches, so why couldn’t it be done for our cars? 🤔
Porsche Brembo 996 BBK Conversion-- let's figure out how to fix the dust boots/seals
Originally posted by r4dr View PostI remember you saying this and I've always kept it in mind. What's interesting is that the mass of the 355x32 rings isn't *that* much greater than the GiroDisc rings. They both have 48 vanes, but perhaps it might help having a proper rear setup as well. You were running a full cooling system with ducts and hoses, correct? Are you still using that setup with the CSL rotors?
Originally posted by r4dr View PostI know I'm biased and I don't pretend not to be, but there are more factors at play here than free rotors.
Yeah, you're not wrong...
Turns out this "budget" kit isn't all that budget at all if you track your car. Love getting sucked into the sunk cost fallacy, so determined to get it somewhat tolerable!
That said, not gonna lie-- I miss my Brembo GTs. They were lighter, they had better pedal feel, I swear braking was better (as in stopping distances, though I understand why that should not be), and they were idiot proof-- with no effort I'd just run them till the pads were done, then on to the next pads. In the almost 15 years they were on my car, I had only 100% positive experiences with them.
It’s no longer “free” though. Yeah we all buy plenty of BMW parts but there’s a limit. Store credit is a lot less useful to me these days since both of my M cars are in very solid mechanical shape. Half the time I want some small cheap part I struggle to even get to the $50 free shipping threshold without buying things I don’t need.
I haven’t done the math but the GTs with their larger 345mm rear rotors might move brake forces at the tire slightly rear which would decrease braking distance up to a point. I’m not sure the usual bias calc of torque applied to the rotors accounts for the extra lever arm.
However, we're also in a thread talking about free rotors... how many people would want to pay $1200 or so for a pair of assemblies?
For most of the time I ran the Brembo GTs, I had no ducting beyond factory/stock.
There's also free pads 🤣
I mean, it's not a fallacy if we can get it to work. Pads/rotors are probably 1/4 to 1/3 the cost of tracking, so if they can be made free, reliably...
TBH, if I were building a track car, I would just buy a 355x35mm Brembo Pista kit. IMO it's the best consumer track day setup for the front of these cars, but you can't get free consumables and the kit costs money.'03.5 M3 SMG Coupe - Jet Black / Black
Also, as far as I know, the widest rotor I know of that comes from the factory with those Megane calipers is a 30mm-thick disc. I have to measure the calipers, but my question would be whether the caliper has clearance for something like a 34mm disc plus full thickness pads. And a few mm of space for stuff like titanium pad shields and allowing for pad tolerance.'03.5 M3 SMG Coupe - Jet Black / Black
Anything is possible. And you're correct, since these calipers are all radially mounted, it would simply be a matter of caliper spacers and correspondingly longer caliper bolts. But it would end up being a custom hat (we could probably use an off-the-shelf Porsche ring so replacements are easy), and the price would be more reasonable if 5-10 people wanted to jump on.
What pads are you currently using via the FCP program?.
Never found a pad I like as much as the old PF01s, but the Hawks aren't even close.
DCT60s... which admittedly aren't very good pads.
Let me ask this... all the cost – both in terms of money and time – to get prepped for the track, to go to the track, and spend the day on the track. Why not spend money to put proper parts on your car and maximize the precious time on track? Instead of doing all of that and ending up with brakes that only last for the first 10 minutes out of a 20 minute session, and every time you push the pedal, you're thinking they're not so great...
Just throwing that out there. I don't even care if you buy GiroDisc or not. I've realized that the time and effort commitment to getting to the track and maximizing every minute out there dwarfs saving a couple hundred bucks in a ridiculously expensive hobby.'03.5 M3 SMG Coupe - Jet Black / Black
No, they're not. And you're being charitable.
I only get ~2 events out them, but that’s fine when free.
It’s really just the seals that are annoying, and so far I’ve dealt with that by… ignoring it and not having dust seals.
Originally posted by r4dr View PostTBH, if I were building a track car, I would just buy a 355x35mm Brembo Pista kit. IMO it's the best consumer track day setup for the front of these cars, but you can't get free consumables and the kit costs money.
With that said I'm putting a Pista kit on my car
Email to [email protected]
Originally posted by D-O View PostHas anyone tried the OEM Porsche dust boots? When I did the 996 conversion on my car I rebuilt the calipers, and while shopping for parts I found that the only thing Porsche sold separately was the boots.
https://www.fcpeuro.com/products/por...e-kit-143370092002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Do you mean the pad thickness of the stock pad size vs the D1001? Or the caliper's max space for the pads? If the latter id assume the stock calipers had a much wider gap for pads, since Ive been having dust boots issues since moving to the Megane Brembos.
I should've mentioned in my previous post that I'm running rear 996 Brembos, their stock dust boots have been holding up fine. I didnt even rebuild them, just installed the used calipers with the factory boots since they looked good and still no cracks or issues, though I havent looked at them since the last track day with the PFC08 pads. I was running lower friction compound GLOC pads rear and I think the fronts were basically doing all the braking work so maybe that's why they haven't been heat stressed and cracked yet (no boots touching either with the 737 pad shape).
Yes, cooling will help tremendously. Stock tunnels are not enough. My first kit that I made was with 2" hoses (one you probably added to your watchlist), that became a pain taking down the bellypan because I routed it through there. Stock shield has a hole cutout on the back of it right in front of the bearing where I attached the hose, so you can go with that as part 1, that helped. After that, I trimmed the shield in such a way that my ball joints are all protected, and it does remove a tonne of shield to help radiate the heat and help with convection.
Rears I monitor, but yes, they don't require much maintenance. My rear pads are maybe 1/4 worn, while I'm on my third front set. Rear Girodisc dust boots are doing fine.
My temp reading on the rear caliper (Alcon sticker strips) barely get the first 121 degree bar (I fully trimmed the shield in rear, and use aluminum tape around the rubber bushings), while my front ones in similar location get to the 400 mark. Makes sense given that the paint I put on the edge of the rotors reads over 1400, I did fade DTC 70 pads at Laguna in T2 so they get over 1200 degrees, conducting into backing plates and ti shims to pistons (forget the dustboots at this point), I've had my 600 degree fluid boil on different occasions (with fuller pad), so then the outsides of the calipers see 400 degrees. That's hot. I feel bad for those seals.Youtube DIYs and more
Originally posted by BigRussia View PostNot to derail or take this thread off topic from 996 Brembos but I think its still relevant; speaking of piston 'upgrades' from aluminum got me looking for my Megane Brembos and found this SS piston kit from RacingBrakes. Seems the FK8 CTR Brembos use the same size pistons as the Megane Brembos. What sucks is that it's so hard to find info on the exact size of the Megane pistons, I know theyre 40/40mm diameter but the depth I'll just have to assume/hope they're 30mm like the CTR's.
For $266 it's not baaad, like yeah it sucks having to spend more money on the budget BBK (and spend the time and labor to rebuild), but even with the full rebuild kit they also sell ($407 with high temp boots upgrade https://racingbrake.com/bh-41bsp/) the Freakyparts Megane Brembo kit + Girodisc 345mm rotors is still cheaper than a Brembo GT 355mm front kit but not by much maybe after the rebuild kit I'd have saved $1k, but still much cheaper than any of the AP Racing kits on Essex (besides the 325mm kit they sell).Originally posted by Slideways View PostWhat about titanium alloy pistons - https://www.silverlakeprojects.com/p...ns-for-porsche. But getting bigger x (impedance, shim, pad, etc) is like getting a bucket to fill up with water vs a cup. Yes the bucket can hold more water, but at some point it will still get overfilled. So depending how long you run sessions for the gradient will get flatter and flatter as everything saturates in heat.
Pistons I already put into the calipers they are barely lighter for both 40 and 36mm (like a gram or so) and 0.01mm larger in diameter vs alu. I expected this with Ti alloys. They should expand less than alu, so went in a bit tighter into the bores.
Originally posted by heinzboehmer View PostJust another data point. Girodisc dust boots did not survive either:
Pads were at about 50% and I was using titanium shims. No brake cooling though..
How often are you replacing rotors?
