Originally posted by bigjae46
Slon Workshop E46 M3 Carbon Front Triangulating Reinforcement Kit
Hard to say cause, as far as I know, only Slon provides chassis twister data along with their products. But yeah, some kind of tubular brace is likely the easiest way to stiffen up the chassis.Originally posted by Maxhouse97 View PostWhat would you recommend to get a close as possible to the rear stiffness gain from the Slon panel …
So notch the panel and then bond an extra part to it? I don't think I'd trust myself to be able to do that and keep all the stiffness gains from the original Slon panelOriginally posted by bigjae46 View PostYou could put a notch where the panel is raised. If someone could bend a metal bracket that fits against the X and CMP brace, I could make a carbon part from it. I'd charge anyone in this thread about $20 plus shipping. Unless you're an a$$hole then you pay the a$$hole tax on top of it which is $10000000.00.
You could. Or just notch it and leave it. I don't think it will make much of a difference.Originally posted by heinzboehmer View Post
Given enough time surely someone here will fab one...Originally posted by ///M3RIC View PostIs there a three point brace option that isn’t carbon fiber and 4k?
If aesthetics / maximum weight savings are of lesser concern, it doesn't seem like rocket science to tie a strut bar to the firewall and achieve a sizeable rigidity gain. I imagine working around the cabin air filter housing would be the trickier part to figure out?
Absolutely no shade towards Slon or the value / quality proposition of their piece, but at that price I'd really have to have run out of modifications to throw at the car to consider it.'04 LSB Coupe 6MT
- Likes 3
bigjae46 - Assume you mean notch out the CMP brace such that the Slon panel could be bonded in untouched and whole. This I agree would probably not make much of a difference to the CMP brace, I think it’s quite sturdy.
On the other hand the other option of going to a body shop and having them weld in a steel panel where the Slon panel would go (could weld straight to the CMP brace as well) in my mind would replicate the E46 sedan with no pass through configuration that is documented to increase stiffness. So that I believe is a third option.‘04 M3
Yes. Welding would be a massive PIA. The cost is in setup and you’d have to cover up so much stuff for a small job. This is a great case for rivets and epoxy. For the inside of the trunk, maybe use some black coated rivets into the Slon panel so it looks good.Originally posted by Maxhouse97 View Postbigjae46 - Assume you mean notch out the CMP brace such that the Slon panel could be bonded in untouched and whole. This I agree would probably not make much of a difference to the CMP brace, I think it’s quite sturdy.
EDIT: might want to use a urethane adhesive since it’s a little more flexible and I think has a higher peel strength.
This makes sense - I had a shop quote me welding a steel panel in. The shop owner attempted to sell me real hard on bolting it in vs welding. I was concerned that a bolted joint would not deliver the same stiffness as a welded joint. Maybe he was pushing that way because of what you mentioned on weld prep.
When you say epoxy were you referring to the steel or welded panel?Last edited by Maxhouse97; 06-30-2024, 10:53 AM.‘04 M3
I really hate to cross post as you should have your own thread since this is unrelated to their front brace.Originally posted by Maxhouse97 View PostOk maybe I don’t have a path to install. I’m certainly not taking my CMP brace out. What would you recommend to get a close as possible to the rear stiffness gain from the Slon panel … buy a GTR type rear brace or weld in a metal panel similar to a E46 sedan with no pass through?
Obvious choice since you already have CMP floor brace is their integrated triangulated top shock tower brace. And probably their front 1/4 panel. These actually tie in the shock towers points to the subframe mounting points. This should far exceed any benefits of that panel, especially on an M3 that already has that C-pillar area strengthened from the factory beyond what the sedan achieves. As you mentioned, along the rigidity gains of a GTR engineered designed brace6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - Euro Bumper - Gruppe M CF Intake - Supersprint - M Track Mode
Both. Bolt/epoxy to the steel and rivet/urethane to the carbon. Steel to steel...epoxy might be superior to a urethane but not sure it would make much of a difference. As long as it is prepped well.Originally posted by Maxhouse97 View PostThis makes sense - I had a shop quote me welding a steel panel in. The shop owner attempted to sell me real hard on bolting it in vs welding. I was concerned that a bolted joint would not deliver the same stiffness as a welded joint. Maybe he was pushing that way because of what you mentioned on weld prep.
Yeah, it would be such a pain to weld for many reasons. Setup and prep. Also its going to be a VERY awkward position.
Do the blower first!Originally posted by Maxhouse97 View PostFinally got one of these - do you think you could do a HVAC blower motor after installing the bracket? I wanted to do this tomorrow but now am thinking I should replace the blower first.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
+1 to doing the blower motor.Originally posted by Maxhouse97 View PostFinally got one of these - do you think you could do a HVAC blower motor after installing the bracket? I wanted to do this tomorrow but now am thinking I should replace the blower first.
Supposedly doable with Slon's mounting point in, but the protruding design seems like it would get in the way of things: https://nam3forum.com/forums/forum/m...146#post196146
Mounting point for the E86 brace retrofit is lower profile and still makes life hard. You can see it installed in the images here: https://nam3forum.com/forums/forum/m...or-replacement2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
So I finally installed my front brace … now let me start by saying I’m a chassis stiffness zealot, but OMG what a difference! I can’t believe how noticeable it is. Car turns in better, rides better, tracks down the highway better, vibrates less. Feels like it’s 10 years younger. I know this sounds like hyperbole, but honesty it’s in my top 3 mods for the car. Such an upgrade.‘04 M3
- Likes 4
100% across the board. Welcome to the club!Originally posted by Maxhouse97 View PostSo I finally installed my front brace … now let me start by saying I’m a chassis stiffness zealot, but OMG what a difference! I can’t believe how noticeable it is. Car turns in better, rides better, tracks down the highway better, vibrates less. Feels like it’s 10 years younger. I know this sounds like hyperbole, but honesty it’s in my top 3 mods for the car. Such an upgrade.‘02 332iT / 6 | ‘70 Jaguar XJ6 electric conversion
