Advice on getting the front differential bolt torqued to spec on jack stands
    Hmm, in my personal experience it has never backed out. I don't go to the track too often though. Can't see it being a problem on a road car if the driver has any mechanical sympathy. I did strip mine and thread repair it, without loctite, and it still hasn't come loose in the 15k miles since. I checked it once in that time and it was tight.
    Makes sense if you can't easily get to the thing with the subframe raising bushings. I only got TMS solids.
    My concern here is that the OP is having trouble torquing it down in the first place, his issue is not that it's coming loose.
      I ran into this a couple of weeks ago, I went to check torque and realized I can't get to the bolt with the CMP subframe bushings. Next time I drop the exhaust the nord-lock is going on.
      Yep, it was an unpleasant surprise after I installed my cmp bushings
        Originally posted by E46m3zcp View Post
        What is your issue? I don't understand what you're saying. How can you use a floor jack to tighten a bolt?
        lol...I didn't explain it very well. I tried using the floor jack to leverage the torque wrench and the wrench wouldn't hold and that failed.
        That is correct. I was unable to torque to spec from the bottom of the car due to lack of leverage so the Nordlock is a safeguard.​
        I lie on my back with my face under the front bolt and knees under the muffler, so you get the orientation. I put the torque wrench on my jeans/right quad and do a "bridge". Makes it pretty easy.
        I will give this a shot. Thx!
