S6-37 6mt swap info (broken off from junk yard thread)
    For what it’s worth (similar internals) I bought a Getrag 560 brand new from Getrag (not a reman) for my personal car and it suffered from the same symptoms as worn ones - notchy 1-2 shifts when colder, generally two-stage shift motion (1-N-2) that the 420 also suffers from, particularly when cold. The ZF internals seem to be less sensitive to this, although I can’t say why without disassembling both. The shift carrier in the ZF does seem to make a big impact, and that cannot be replicated with the Getrag. It’s a small difference, not everyone will care or notice, and everyone is free to not change their factory M3 parts of course
    At least from my experience, there is an improvement with the ZF box, but it’s not as big of a change as I’ve felt from ZF -37 to ZF -53. Tradeoffs!
      Keep in mind the diesel engine/transmissions are 20* so if you bolt that trans to our engine it will be 10* of horizontal.
      Thats true at the bellhousing end. But if you’re using the N5x variant of the transmission, the bellhousing has the correct tilt and the rear case will line up as it is supposed to with the 330d parts.
      But without a solution for the flywheel and clutch, it’s a bit of a moot point regardless
      There is someone making any adapter to do just that but I'm not sure what the benefit is when a stock clutch is likely just as capable at holding stockish power.
      Well the non-M input shaft is physically shorter so it won’t reach the pilot bearing in the crankshaft. So if you want to use the much easier to find non-M variant of the transmission, you either have to use the 330i flywheel (with integrated pilot bearing) and clutch, or devise some means to space out the pilot bearing if you want to use the Z4M/M3 flywheel with the Z4M clutch (or any other 22-spline clutch/pressure plate combo that might fit).
      I can’t say for certain if the M3/Z4M flywheel is better suited for this engine, but I imagine it is.
        Yep, fair enough. The jump from 1st to 2nd is likely going to be noticeable compared to the 420G. Can't say how much without actually feeling it though. I need to drive a Z4M before fully committing to this swap, but the math has me pretty convinced.
        And good point on the graphs. I posted pictures because I figured it was the easiest way to share. In the spreadsheet I made, I calculated speeds at 10 rpm increments so that you can mouse over the graphs and look at the numbers that correspond to each. Here's a link to a read only version (make a copy if you want to mess with it) of the spreadsheet in case anyone wants it: https://docs.google.com/spreadsheets...it?usp=sharing
        heinzboehmer,
        The gap between 1st and 2nd will be barely noticeable.
        I spotted something more interesting 2nd to 3rd the RPM
        drops down to 5300rpm instead of 5250rpm for the G420.
        SG6 2nd gear at 2.50 is taller vs 2.53. At 2.50 the gear is closer
        to 1.66 means less RPM drop. This is right were the HP starts
        to climb and make larger increments. If you note those say +/-60rpms
        will add around +/-8rwhp which is good thing.
        So basically the SG6 is better than the G420 from 2nd to 3rd
        which is more important than 1st to 2nd.
        Believe me little shorter 1st is not going hurt the performance
        at all. It has been years now I have not seen single I mean single
        E46M3 with stock wheels...any aftermarket setup will add drag
        to the M3 and little shorter will help to lift the additional drag/weight
        added over stock wheels.
        Thanks for making the chart it's similar to mine.
        Regards,
        Anri
        https://www.instagram.com/euroclassicmotors/.
        www.euroclassicmotors.com
          Hi,
          Kaiv told me every 420g feels different and some are way smoother than others
          Let me lay down the Schematics what is involved in the
          "shifting feel characteristics" on any transmission.
          I want start with shifter deign. BMW has been using the
          same design since 1983. Installing short shifter kits they
          indeed change the leverage and also eliminate the OEM
          bushings which are there to eliminate noise, and smoother
          shifter feel. Ones short shifter kit is installed the transmissions
          noises are all transmitted to the shifter.
          In the pic the Selector shifter long rod has arc/seat, ball, spring.
          If the shape of those machined arc is deep the shifting feel will
          be notchy with addition to the spring rate. At installed height
          they are pretty hi....18lb...So if I reduce the spring pressure and
          the depth of the arc/seat those parts the shifting characteristics
          will become softer and less mechanical feel.
          The reason why G420 2nd hooks on a cold weather is because
          it's the gear that sees the most abuse from all the rest.
          G420 has 3 piece Synchronizer design for smoother shifting.
          When the 3 piece synch start wearing out and the clearances between
          the synchros do get larger more oil gets stuck in and the reason why
          it's getting harder to upshift till the oil sees heat and then is back to normal.
          3 Pics Synchronizer does not like many errors from the driver, what
          I mean is some time during the life span the driver will randomly
          grind the gear either one but 2nd as I mentioned is the most abused
          of all the rest. When the shifter rod arc also starts to wear out the
          ball with the tired spring will also affect the shifting feel and the reason
          why there are many variation in the G420 primary the synchro and
          then its the rest.
          This is why the SMG is better to convert because it almost never
          made an error grinding the 2nd gear and the synch condition is
          much better.
          1 piece synchro is much more rigid and can take a lot of driving
          errors/grinding vs 3 piece.
          On my M5 the G280 with MT90 on cold weather (45F) shifts the
          same way if outside is 90F. This is because the Synchronizer is 1 piece.
          The G280 requires ATF oil, thin viscosity. On a customer of mine
          with E39M5 2nd gear started getting hard in mornings and I changed
          the oil with ATF and it improved by a lot in those cold mornings.
          Regards,
          Anri
            Anri, do replacement parts exist for the 420G and is there a shop that can reliably rebuild (replace syncros) for the 420G? A few years ago, some shops were saying that this gearbox was very difficult to rebuild.
              Hi,
              The G420 box used to have a Patent on the Synchro and
              pretty much on all the parts but several years back I think
              the patent dropped...and the company started to sell
              Synchronizers only. No other parts are available what so ever.
              If the shifting fork wears out which is responsible to keep
              the gear in, then you get pop-out of a gear scenario and
              then the tranny become part out....or find good unit with
              synch issue and swap the shifting fork/s.
              I have a tranny guy who I use for rebuilding one of those,
              have done 3-4 so far.
              Regards,
              Anri
                Saw this thread the other day and meant chime in. I have an S54 touring in the shop running a full ZHP trans. It's all a direct swap with a modded driveshaft.
                IG: @limited.slip
                Alpine White E90 M3 6MT
                Alpine White 1 Series M
                  Terra,
                  Remember BMW engineers will never do anything without
                  a concept they have in mind, otherwise they would have had
                  the G420 on std 330i as well...make 1 gear box for all, just like
                  Mercedes loves to do this trick. they use the same box from
                  1.8 S/C up to 2.0 up to 3.2 V6 S/C.
                  The G420 is also covering E39M5 only the bell is different.
                  That's not the only difference. The input shaft on the V8 420G is longer than the I6 spec 420G.
                  IG: @limited.slip
                    This is very true. The Autosolutions kit made my 420g a lot more fun. Kaiv told me every 420g feels different and some are way smoother than others so maybe one day I'll get a low mileage trans from an SMG swapped in and see how much better it is.
                    To clarify my statement for everyone, my observations are after doing well over 100 SMG to manual conversions, all with the same bellhousing work, same shifter etc. There is a range within which most transmissions fall and they feel mostly the same. But every once in a blue moon you have one that a bit harsher than average or one that's exceptionnally smooth. I'm guessing it's part manufacturing tolerances, part wear and tear over the the life.
                    IG: @limited.slip
                      Kaiv,
                      I was pointing the G420 was specifically designed to go in M5
                      and M3. E34M5 G420 6spd also have different input shaft but
                      the design is the same.
                      I have had rebuild 20+transmissions and with mixed match
                      bell housing some went to NASA E30 M20 spec and other model
                      Getrag's for street driving.
                      I can't see the bell hosing having affect on the shifting characteristics.
                      I have also converted SMG to manual and I have never seen anything
                      different in shifting characteristics. If the needle bearings are worn out
                      and etc that is different.
                      Changing the shifter fork, new synchronizer, new springs, the gear box
                      will shift just like it came from the factory.
                      Unfortunately those parts are not available for G420 and nothing can
                      be done.
                      Regards,
                      Anri
                        What flywheel?
                          I had a Z4M Coupe and 1-2 was notchy. And peoples on Zpost were also complaning about it over the years. Not sure it will be a night and day difference if someone do the swap.
                          2006 BMW E46 M3 Individual Estoril blue/Black 6mt
                            I kind of lost interest once I realized I own a S6-37 already (in my 128i). I don’t think it shifts any better, even compared to the completely stock 420g in my e39 M5… much less compared to the auto solutions kit in my e46.
                              I kind of lost interest once I realized I own a S6-37 already. I don’t think it shifts any better, even compared to the completely stock 420g in my e39 M5.
                              From what I remember, I think my low mileage Z4M Coupe feel worse than pretty much any E46 M3 I drove while shifting 1-2 on the street. More notchy.
                                Gents,
                                Is there a bench mark how a transmission should shift ? absolutely not.
                                In general people do not like notchy gear shifting....
                                Someone few pages back mentioned that g420 "it will never be Honda" lol
                                I think Honda shifting is absolute garbage empty feeling, but that is just me.
                                I personally do like as notchy as possible so I can feel the gear mechanism
                                going thru the gears and way better control and feeling driven with anger.
                                Clack, clack, clack....
                                Regards
                                Anri
