S6-37 6mt swap info (broken off from junk yard thread)
    Nice. Yeah that's probably the simplest way to do it. I know there was some concern that the flywheel from a 330 wouldn't be well matched to an S54, but we're talking subtle stuff anyway at that point
      Originally posted by e46IX View Post
      FWIW I just slapped together a Z4M Roadster for a friend, with mix and match used parts.
      I used a ZF GS6-37 from an e46 330i, the Z4M shifter attaches directly to it.
      I used a flywheel from an e46 330i, and removed the pilot bearing from the S54 (330i flywheels have integrated pilot bearings)
      I used the clutch kit from the Z4M, and the starter from the Z4M (same as M3).
      Everything works mint, transmission engages and shifts like butter.
      I've had both clutch kits next to each other (330i and Z4M. They are virtually identical and all 3 clutch discs (e46 330i, e46 m3, z4m) have a 240mm diameter. There were some minor differences in the pressure plates between 330i and z4m but didn't cause any issues, car drives perfectly normal.
      I read that the input shafts have different lengths between the Z4M and 330i gearboxes. Does that not matter since you mixed and matched parts - mainly the location of the pilot bearing?
        Well done!
        Has your friend done any aggressive driving yet, shifting at redline? I've read reports of Z4M cars struggling with shifting at redline and that was attributed to the GS6 transmission as this was not an issue with E46 M3 with the 420G. Wondering if the GS6 from a 330i with the shorter input shaft exacerbates this issue even further?
        Another question - why did you choose to go with the Z4M clutch kit over the 330i one? Clearly it works and there's a chance it's slightly more capable of handling the S54 power but considering you used the 330i transmission and flywheel, 330i clutch would have been the safest bet which is why I'm wondering how you decided to go with the Z4M clutch assembly? Again, just curiosity in case there's something new to be learned as I love the GS6 transmission and plan to use it if I ever do an S54 swap on my E46 sedan.
        Cheers
          That’s why he had to use the 330 flywheel with the integrated bearing.
            Gotcha, so the Z4M has the longer input shaft as it has to reach the end of the crankshaft and the 330i is shorter since the bearing is on the flywheel. Now I'm curious why BMW wanted to use a specific flywheel for the M3 and Z4M rather than use the clutch assembly and transmission from the 330i in the Z4M.
              Originally posted by PetrolM3 View Post
              Well done!
              Cheers
              In my case it was just a question of what we had lying around, he bought the Z4MR as a lightly hit car that was being parted out, it was sold to us as a rolling shell with no powertrain and we put the car together on a budget with spare parts we had kicking around. I'll get him to report on how the car holds up to aggressive driving, give him a week or 2.
              Yes, the Z4M ZF GS6-37 does have a slightly longer input shaft than the 330i variant, the rest of the transmission is 100% identical (minus the shifter but that doesn't matter they can be swapped out for each other).
              I will be using the Z4M version of the GS6-37 for my personal E46 M3. It will be mated to the original S54 flywheel and a Z4M clutch kit. I got Ronald to sell me one of his 330i 6MT SSK.
              The only part I need to figure out next is the transmission cross brace, as I heard the cross brace for the ZF gearboxes interferes with the stock M3 mid-pipe. I'll see for myself once I'm putting everything together and decide what the best course of action is. Seems like most guys get an exhaust shop to modify the mid-pipe but personally i'd rather cut and well the transmission cross brace itself otherwise it will always be a headache to change exhaust components on the M3.
                As for the redline shift grind, yes its a real thing even on my own personal low-mileage (50,000 km's) M Coupe. I normally hesitate for a second going from 1st to 2nd on a redline WOT pull otherwise it will grind, can't just slam it into gear. Although to be honest I recently changed the trans mounts out for the Rogue Engineering solid rubber ones and I think there is some improvement there, I may try going to slightly stiffer engine mounts and see if limiting the movement in the drivetrain will help solve that grind.
                  Thanks for sharing, much appreciated!
                  There's another forum member on here who was looking to replace his 330i GS6 with a 420G and he was using a customer made cross brace - he recently posted in the classifieds looking to swap his GS6 with a 420G so it should be easy to find him if you want to see what his custom cross brace looks like, I'm sure he'll be happy to share.
                    Yeah it's a fair question. I think it just comes down to *technically* the dual mass flywheel should be relatively matched to the engine's characteristics. And I guess it was cheaper for them to make a few transmissions with a longer input shaft than making and perpetually stocking a Z4M-specific flywheel.
                    In my mind it should be feasible to build some sort of spacer that sits in the crankshaft and spaces out the pilot bearing to where it should be for the shorter inputshaft while using the S54 flywheel. But the machining would need to be spot on.
