Originally posted by ac427
View Post
1. Turn ignition (NOT engine) on and heat to highest setting
2. Crack open bleed screw and slowly add coolant/distilled water mixture (~2 gal)
3. Close bleed screw once coolant begins to leak out of it
4. Start engine and keep heat on high
5. Slowly open and close the bleed screw to release air as coolant gets up to temp
6. Once coolant is up to temp, slowly open/close the bleed screw one last time to let remaining air out
7. Slowly open/close the bleed screw after the next few drives to release any potential residual air.
