Hi fellas, can anyone share their 375-380mm rotor & caliper setup under an 18" wheel? Photos would be great and please specify radial & lateral clearance as well. Thanks!
375-380mm rotors/discs under 18" wheels
AFAIK there's only 1-2 18" wheels that'll clear 380s... I'm tempted to say Volkes, but not certain on that.
Really, the same thought process that leads you to wanting 18" wheels should lead you to wanting 355mm brakes-- lighter, better performing, cheaper wear items, only a cosmetic "penalty" in exchange.
Originally posted by Obioban View PostAFAIK there's only 1-2 18" wheels that'll clear 380s... I'm tempted to say Volkes, but not certain on that.
Originally posted by jareds941 View Post
I mean to be fair, the larger brakes will perform better, at the limits on track.
https://www.essexparts.com/essex-des...668355mm-e46m3
You'd need to have a pretty hot e46m3 to approach the limits of a Brembo 355 kit with race pads, good fluid, and cooling ducts. The AP racing competition brake kit uses 355x32 rotors and radical 6-piston calipers which is the go-to for most racers...
Anyways, back on topic. Looks like Hyperboost had some good info for the OP
Noted to both you and Obioban. Not that I had any intentions of anything more than 355. I had been planning on this kit for some day https://www.essexparts.com/essex-des...060355mm-e46m3 but seems to be discontinued now.
new caliper: https://apracing.com/race-car/brake-...25mm-thick-pad
old caliper: https://apracing.com/race-car/brake-...mm-thick-discs
Yeah it was replaced by https://www.essexparts.com/essex-des...668355mm-e46m3 which uses a newer caliper.
And price went up at least $1k from my memory 🤣I'm sure they are better...
BMW parts & BMW accessories since 1993. Turner Motorsport is the #1 source of high performance BMW parts, OEM BMW replacement parts and BMW accessories. Specialists of BMW brake parts, BMW suspension upgrades. | Turner Motorsport
I'm not sure what the real world benefits over a 4pot kit of the same size are though, and if it’s worth the price.'03.5 M3 SMG Coupe - Jet Black / Black
I believe Apex EC7's and TE37's with the right offset will clear 380mm rotors. IDK why you'd want them though. My Brembo GTR kit is heavier than the stock setup and they're only 4 piston calipers with 355m discs. Imagine what a bigger rotor, bigger caliper and bigger pads weigh more? Obviously not a ton more but you're adding weight to stop better. Car is relatively light, it doesn't need 6 pistons to stop. Needs good tires, pads and fluid at the bare minimum.2004 BMW ///M3 Carbon Black/Cinnamon 6MT
2005 BMW ///M3​ Interlagos Blue/Black 6MT Dinan S3-R
Originally posted by Sharocks View PostI believe Apex EC7's and TE37's with the right offset will clear 380mm rotors. IDK why you'd want them though. My Brembo GTR kit is heavier than the stock setup and they're only 4 piston calipers with 355m discs. Imagine what a bigger rotor, bigger caliper and bigger pads weigh more? Obviously not a ton more but you're adding weight to stop better. Car is relatively light, it doesn't need 6 pistons to stop. Needs good tires, pads and fluid at the bare minimum.
The benefit to 6 pistons is larger pads, which gives you longer longer pad life. I don't think it's worth the trade off, but that is a benefit... the only benefit AFAIK.
I have to say, my Brembo GTs (355/4 front, 345/4 rear) are one of the best mods I've done to this car. I've now had them for 14 years/140,000 miles/20,000 track miles, and they've been 100% flawless throughout that entire time. I believe they are the only mod I've done to the car that I haven't later redone with something else/better. I can't see any room for improvement. (well, I see the allure of free rotors/pad by using FCP, which they don't allow, but that's no fault of theirs... and I decided that benefit wasn't worth the trade off in performance).
