"StopTech Has Shut Down USA Operations"
    Originally posted by Teemmy View Post
    Oh man. I just bought a m3 with stoptech st60 380mm rotors and need to figure out replacement pieces when the time comes 😅
    Car came with track pads and the car sounds like a freight train so now I need to find street pads!
    Girodisc has the rotors (380x32) and the pads are an AP Racing caliper pad shape.
      That's excellent! Don't know if you can recommend some good street pads for the st60 and st40…
        I have the ST40 Trophy calipers (front and rear) on my 1994 NSX and use their Sport pads. P/N 309.06080
        I found they have excellent cold bite and wear characteristics. Low dust and nice rotor finish. Cost is around $100 per axle. For street and spirited driving these are all you need. ​
          I found they have excellent cold bite and wear characteristics. Low dust and nice rotor finish. Cost is around $100 per axle. For the street and spirited driving these are all you need. ​
          Those are the ones I was thinking of buying and I thought I saw somewhere they have a brake pad sensor version too. I'll have to dig and find some pads that can accommodate the brake pad wear sensor.
            The ST40 pads (I think that part number above should be 309.06090) should all have wear sensor cutouts because it's technically a Porsche pad shape. The ST60 uses a race pad shape and I would guess none of those pads have a wear sensor cutout.
            There are part numbers for PFC Z-rated street pads in both shapes. If they exist, that would be a good bet for a street pad.
              Awesome! Thank you
                Just to bring this back... Looks like Stoptech (First Brands) has started to wind down operations in North America. The story is pretty juicy, with creditors trying to trace hundreds of millions of dollars of alleged fraud by First Brands Group's former leadership team. Yikes
                The First Brands case highlights the investigation by Nardello & Co. into hundreds of millions in assets related to fraud.
                  That's actually crazy. Luckily, the F8X BBK is here to save us all!
                  '05 ///M3 Mysticblau Metallic / Grey Nappa 6MT
                  '24
                  Audi RS5 Nardo Grey / Black​
                    Oh Damn
                      Im going to try living with mine for as long as possible before i go the F8X route.
                        what are good street pads everyone is running these days? I have stoptech (not bad) but feel like there's more to be desired.
                          You probably will never need another BBK as long as you don't damage the caliper body. Rotor hats, rotor rings, piston seals and almost everything else can be replaced with another brand.
                            Porsche Textar pads - https://www.fcpeuro.com/products/por...ar-99335193901
                            Backing plate needs a bit of clearancing where the silver spring clip on the bridge holds the pads in.
                              Oh wow, these fit the stock calipers? thanks for the link as well!
                                Yes, the backing plate will need some light machining to get the spring clip on the bridge to fit. You know how much trimming is necessary by putting the ST pad backing plate against the Textar backing plate.
                                Roughly where the red boxes are needs to be machined off:
